Best block for reliability for high HP?
So cylinder pressure isnt just cylinder pressure...in the same way detonation and pre-ignition arent the same either, with the former being far more destructive than the latter, although both can kill an engine in no time.
But both are also examples of cylinder pressure simply at the very wrong time
If you're happy with iron, then of course the LSX is a good base to work from.
Bare LS9 block is circa $4k, so not cheap...but again, it does have some nice extras vs other blocks
https://www.gmperformancemotor.com/parts/12623969.html
https://www.jegs.com/i/Chevrolet-Per...23969/10002/-1
LSX is cheaper, not sure of all the variations and/or supporting parts needed to make them work though which might add some cost again.
https://www.gmperformancemotor.com/category/LS196.html
Thanks for stopping in. Do you have anything to add or throw your .02 on?
LS9 is the strongest of the alumimum blocks. L33 next. Then LS2 ahead of LS3. Though I've heard LS2 is stronger than the L33. It's possible since most of the bore change comes from the liners and not the block itself.
LSX are a step up to either along with the Dart SHP. I believe both are rated to 2K HP with 1/2" 6-bolt head studs. Though I think I'd trust the Dart block more due to it's changes on the bottom half of the block (splayed caps, oil squirters, etc).
Then moving on to the billet stuff from RHS or Dart for anything above 2K.
But for 1k HP and under, pretty much any Gen IV block or the L33/LM7 Gen III stuff would work. Use an LS9 gasket, ARP head studs, and soften the chambers of whatever heads you have to help with pushing water.
This is where matter of opinion (which I am open to) comes in on what is the reliability point. I am leaning towards the 6-bolt that the LSX offers right now as the jump up from the 6.0 to that is not really a ton of $. Thoughts?
Yes, but you'll also be pushing that 5.3 a lot harder than I would a 6.0 block with greater displacement. I am not set on a factory block. I want whatever is reliable for consistant 1,000 RWHP. Understanding there are some that will fit the bill and others that will far exceed what I am looking for and cost a lot more. I don't want to spend $5,000 on a block if spending $2,800 will do the job just fine.
http://dartheads.com/product-categor...t/next-blocks/
Really, if weight does not bother you at all, and budget permits then yes some of the iron blocks will be a stronger base for the money. Not sure how many of the OEM bolt on parts fit these blocks though or if more parts are needed to fit them. That does apply to LSX too though, where additional parts are needed.
Other than the weight of the aluminum LS9 block, I guess I can't see the advantages of spending the extra $ on the LS9 over the LSX. Is there something else I am missing? Both should be overkill for what I am looking to do (I think the LSX block is rated up to 2,500 HP).
If if I wanted to pony up and extra $1200 I’d do LS9 easily but when I build mine I’m just gonna use another LS3 block. Hell the LSA block has oil squirters also and supposed to made from
stronger material than the LS3.
For piece of mind just for LSX cause I think that’s what you’re leaning towards. Dart is the one I’d be looking at though.
I will be strarting from scratch, so I'll need everything. So, as long as I know what bolts to get, and they are not crazy more $ than OEM bolts, the different aftermarket blocks don't bother me.
I think you missed his point being that it’s taken a lot of boosted punishment. 7 years to be exact.
I am not familiar with the Dart blocks. I will look into them for sure. What is it about them that makes you lean towards the Dart block over the LSX block?
As a side note, I do really appreciate all the input and the info everyone has given. I am learning a bit here.
My buddy made close to 1000 for several years in his 346/YSi build. It was holding together fine until one day at the track when the 2 step malfunctioned and he dumped the clutch at about 6000rpm. Twisted the block like a pretzel. Still didn’t push water though. He’s been 157-158 in the 1/4 more times than I can remember.
Best of success with your build!
I feel like going on the side of caution and just going with an aftermarket block. Dart I like for the extra oiling, but LSX has been used more and there is more data on guys using them to get info on. I need to do more research either way.
Unfortunately this is going to be a LONG term project. I have been focusing my extra time and money with my career this last year or so, and will be for the next year or so before I will have enough extra time and $ to get this project actually going.
In the mean time it's nice to figure out an actual direction I will he taking it. Who knows, perhaps I may even be able to take some $ and start with the block and get parts as I go.
The simple fact Pete is saying a basic LS1 block 346 can survive the power and it is one of the weakest block options....proves the point it isnt a huge ask for the better more recent blocks.
So, could a factory block hold up fine for years? Clearly it already has for some. It also has not for others. Unfortunately with all the variables and stories on each side of the spectrum I still feel like siding on the cautious decision would be best. It also seems that the cost difference would realistically only be in the $1200-$1500 range for the added strength the LSX or Dart block would give. In the grand scheme of the build, that's not a lot extra for the extra level of strength it gives.
Before I was in this position, I was told by some that my LT1 block would hold together (others said it would not). I had dedicated a large amount of time and money to make over 1,000 at the wheels with it. After it flexed the block, needless to say it left me wanting to side this next time with the block more likely to not fail on me. I am not final with my decision as I have plenty of time to decide. But as of right now, I am leaning towards the LSX or Dart block.
i used to run my LS3 sbe with a single 7675 turbo on 93 Meth (10.7:1 CR). I couldn’t keep plug wires alive but made 817rwhp/758rwtq @ 16psi with ignition issues. I believe I could of hit 900rwhp with 18psi on a clean pull (not burning plug wires). This setup did see like 60 dyno pulls over 4 different trips to the dyno and some street pulls
I pulled led the short block and put it in my gto.
I now now have a 416ci 10:1 Twin 6266 turbos and the goal was 1000rwhp @ 16-18 psi on 93 + Meth. Gonna hit the dyno in October.
Yeah, I'm not worried about Dyno pulls. Even a bunch of them are still just a few seconds at high boost and speed. Similar to 1/4 mile runs. Many people do this, get away with it and claim it's good to go which for just that it probably is. I'm more concerned with extended runs and 1/2 mile and full mile runs where the car is at high boost for extended periods of time. It's a lot more stress on a motor to hold that cylinder pressure than just quick pulls.
When the time comes, whatever I decide, I am confident my power goals will be met (1,050-1100 RWHP). My S484 turbo is capable of it easily with a good setup. I just want to make sure I don't have to go down that same road of looking at catastrophic engine failure after all the time and $ spent.
