loud valve users....
Old Sep 4, 2018 | 01:53 PM
truckdoug's Avatar
Default loud valve users....
how the hell do you keep your **** from rattling at idle?
like a steering wheel for a beltbuckle COZ ITS DRIVING ME NUTS
Old Sep 4, 2018 | 01:59 PM
svslow's Avatar
Add some preload to it by shortening the arm.
Old Sep 4, 2018 | 05:57 PM
truckdoug's Avatar
done that several times. it gets hot a couple times and goes slappy again
Old Sep 6, 2018 | 04:23 PM
stevieturbo's Avatar
what's a loud valve ? Maybe try a quiet valve ? lol
Old Sep 6, 2018 | 06:35 PM
JST4FN's Avatar
I’m glad I’m not the only one. Mine leak little puffs at idle and now have a slight rattle. If I grab the arm and pull it tighter they seal off, but no adjustments made corrected it.
Old Sep 6, 2018 | 07:10 PM
93hatch's Avatar
try a spring pulling it closed
Old Sep 6, 2018 | 07:27 PM
cam's Avatar
cam
You need to get old valves after they grow up they quiet down a lot. Its all the youngins full of clicks and clacks you need to run the **** out of them for ten years until they grow up and quiet down
Old Sep 6, 2018 | 08:01 PM
badass68's Avatar
This is why gm used vacuum closed valves on vettes and camaro. They always have pull on them.
Old Sep 7, 2018 | 01:33 PM
Forcefed86's Avatar
Yea,mine are normally open and pull closed with VAC. No rattle.
Old Sep 7, 2018 | 01:48 PM
cam's Avatar
cam
I've been thinking about this, because a solution is sorely needed. In 1969 GM added a coil spring to the truck area of the Camaros to cut down on rattling so im thinking if we added a well aged vacuum spring bolt on the rear of each head like a knock sensor type deal, that ought to absorb the loud valves.
Old Sep 10, 2018 | 11:41 AM
truckdoug's Avatar
yo, thanks dog. life is better now.
Old Sep 11, 2018 | 05:46 PM
93hatch's Avatar
Old Sep 12, 2018 | 09:49 AM
Forcefed86's Avatar
Was just looking at my normally closed valves last night. Yours don’t have an adjustment on them? They should already be pre-spring loaded closed with the spring in the diaphragm. Should just be able to tighten up that adjustment? I dunno mine were $60 straight from china and I skipped the middle man. Maybe yours don’t have the adjustable rod end?
Old Sep 12, 2018 | 11:45 AM
3 window's Avatar
[img] https://image.made-in-china.com/43f34j00iOsazWBPgbuU/Normally-Close-Vacuum-Pneumatic-Exhaust-Valve-Cutout.jpg
How quickly do yours close on start up? Need to be able to sneak out of the garage in the a.m. to head to work.
Old Sep 12, 2018 | 11:53 AM
Forcefed86's Avatar
Wasn’t fast enough! I run a little $2 12v vac motor on it now. Let it run for 30 sec or so before starting so I don’t wake the baby.
Old Sep 12, 2018 | 12:55 PM
truckdoug's Avatar
yeah I adjusted the hell out of mine. Actually broke the first one---couldnt get a replacement diaphragm---and bought one from ali express. It was the exact same unit lol I bet i could fingerprint them both and come up with the same 12 year chinese girl
It just rattles badly at idle, i'd adjust it and it'd be fine for a few days and begin to rattle again. My guess is the preload spring gets hot and looses uh, springyness
Added a random spring from a carburetor spring kit and it's enough I don't hear it so I'm cool.
That is a neat fix you came up with tho.
Old Sep 12, 2018 | 01:02 PM
3 window's Avatar
Doug, at what boost does yours open up?
Old Sep 12, 2018 | 01:54 PM
truckdoug's Avatar
maybe 1 or 2 psi manifold ?
Old Sep 12, 2018 | 02:42 PM
EarlH's Avatar
Are you running a boost activated or vaccuum activated valve? normally open or normally closed?
Old Sep 12, 2018 | 03:15 PM
truckdoug's Avatar
boost activated, normal closed
