Holley hp EFI, 03 4.8 base tune?
So i was hoping someone might shed some light on what cal to start with for my setup. Or if someone could share a tune from a similar setup, that would be even better lol. Thanks for any help.
Setup is.
holley hp, V4 for ls1
Stock 2003 4.8
Ls6 intake
Return style fuel system boost ref reg
HPI 120 lb @ 43psi injectors
Billet 7075 Turbo
E85 fuel on gas Afr scale
Trans th400
Setup is.
Stock 2003 4.8
Ls6 intake
Billet 7075 Turbo
Trans th400
I would start with the ls1 cal and then make the changes needed for your setup, You're going to make so many changes that it doesn't really matter.
If the cal is setup for gas and you are starting with E85 on the gas setting you may have to add fuel (I had to add 30%) across the board to your fuel table to get enough fuel to start.
You also want to make an advanced table to pull timing as boost increases at least until you get a handle on it.
I set a lower Rev limit until I feel that I'm getting handle on the tune, It's real easy to break the tires loose and spike the RPM's higher than you'd like and with the tune not being dialed in bad things can happen fast.
You'll need to make several changes
Select the correct o2 sensor for your application. (Not doing so can ruin the sensor)
Change engine displacement.
Change injector size and put in your injector data.
Check that all sensors are correct for your application.
Remove the 4l60e transmission.
I'm sure I'm forgetting some, Just take your time. Initial setup needs to be right or you'll chase your tail trying to get it going.
I've done 3 that were boosted and never started a single one with a 2 or 3 bar map. I used a stock 6.0 ls2 dbw cal for 2 and the 5.3 for the other and just changed to a GM 3 bar map, Worked fine for me.
If you change from a NA map sensor to a 3 bar (or any other) You get this message.
Fuel and timing scales are changed.
Before map change
After switching to GM 3 bar map
To prevent killing plugs right off the bat, you want the CL working right away. Holley has a
couple turbo global's you can use as a start. Matt has a tune on his site, you would have to change
to your injs, etc. I could send mine, but I use a flex fuel sen., I use the Holley 120's, GM 2525 Map. sen.
I also found when you use another tune with different injectors you usually have to adjust the fuel table before firing anyway.
I guess whatever works for him.
Good info guys, kind of curious if any of you have tried the LSx 364ci 850HP 20PSI DBW tune? I played around and molded that tune and deleted the things that I don't have on my setup. Changed the CI , and made the target air-fuel ratios a little richer for the e85. I also deleted about 2 degrees of timing in all the areas where I would be making boost. I have not tried to crank it yet, but probably will here in a couple hours, I still need to change the injector data to match my injectors.
From the Holley files.
Fuel Injector Information - Set - Off Time
Description: The injector off time curve (or dead time) is basically the effective time where there is no flow between the time an injector is commanded open and closed. This is specific to every injector as well as the system operating voltage. Pressure also affects this number. The 1x16 curve in the software accounts for varying system voltage.
Holley includes a sheet that has this data for all of the injectors Holley offers as well as some other commonly used injectors. If this information is not entered correctly, the base table fuel flow numbers will not reflect what the real fuel flow is. Also if the system operates under different voltages, system stability can be affected, especially at idle. Note that injector information is available in the contents section “Appendixes” in your software.
I found it on the site all you do is go to the search function and type in data, I'm more confused now than I was before , im really not sure how to read or get the information I need from what I see on the site.
If you have any questions send me a PM with your number and I'll give you a call. It might be easier to figure out that way.
