Dirtybird
Old Jun 23, 2019 | 03:07 PM
Transamthunder's Avatar
Old Jun 23, 2019 | 03:12 PM
Converting my back up t56 from lt1 to ls1
Front input shaft is lt1, back one is for ls1
Old Jun 23, 2019 | 09:18 PM
Before the butchery
More cutting needed
Sawzza and grinder with cutoff wheel are the only tools at my disposal. Gonna try and get a dremal to clean this all up with. A lot of work to pit in an On3 radiator.
Old Jun 30, 2019 | 04:31 PM
Old Jun 30, 2019 | 08:16 PM
Having a hard time getting rails to go into their homes
Found a table on wheels to make a stand out of for cheap
Old Jul 28, 2019 | 04:17 AM
Starting the switch from auto the manual pedals. The one thing I am unsure of is the bracket seems to move around about to get an accurate locarion to drill for the clutch master
Some evay headers I tried to use, but they def dont work on the 4th gens. Clearance issues with waterpump coolant bypass, and on driverside with ps pump and the steering shaft
Seen someone cutting up a bumper to use as a bracket for the intercooler. We will see how it turns out. Just got the foam part off. They are just held with some push pins, prolly the biggest I ever say anyhow.
Old Jul 28, 2019 | 08:12 PM
Haven't done the bumper cover yet, but just mounting the inter cooler after cutting up the bumper was a big win for me today.
Old Aug 2, 2019 | 10:34 PM
Over all came out ok. This is an On3 stand up rad. Info isnt to really out there for doing this, and they include no instructions on doing these.
Some brakets I found at Walmart to help add support because I cut a lil to much out.
Old Sep 14, 2019 | 10:03 PM
Rear end out to make room for ford 8.8
Old Sep 14, 2019 | 10:05 PM
Triple pump threat. Three Walboro 455l pumps to hopefully rock flex fuel.
Old Jun 6, 2020 | 11:55 PM
New turbo kmember.
Old Jun 7, 2020 | 12:31 AM
  #32
Had a tarp, and it still leaked through, and put a gallon of water in the engine. Good thing it was getting pulled to put in a bmr kmember.
New k member installed
Finally in.
Engine and trans going in from the top.
Old Jun 7, 2020 | 12:40 AM
  #33
Dragframe's Avatar
She’s coming together man. Keep it up!
It’s funny cuz I named my red turbo 2000 ws6 the Dirty Bird. She was a relatively nice car when I got her in 2012. But the years of dragging it around to completion this year really took a toll on her! Hence the name lol.
Your thread looks a lot like mine. I guess nobody gives us red fbody guys any love these days
Old Jun 12, 2020 | 09:05 PM
  #34
I hear ya man. I got mine about a year after you did.
Old Jun 13, 2020 | 07:29 PM
  #35
Sneaky way to mount since they look small enough
i like this angle as I can maybe utilize my cheapie ws6 hood, and also keep my abs module and battery in place. These turbos are almost the perfect size.
Old Jun 14, 2020 | 11:09 AM
  #36
Dragframe's Avatar
Ditch the abs! It’s heavy and just kind of annoying. It’s pretty cheap and easy to replace. SJM manufacturing makes a lil kit to do it too. Add a line lock while your there if you want.
Old Jun 19, 2020 | 01:04 AM
  #37
i haven't figured one way or the other which I want to do yet. i kinda wanna keep it.
Old Dec 7, 2021 | 11:22 PM
  #38
Holley 12.3 dash being trial fit
Dash bezel needs trimmed
Ford racing 3.55 gears since I have a 6 speed
Ported 243 heads
Huron twin turbo kit
Alt relocation kit
Short throw shifter from Hinsen
Speed Engineering twin exhaust
Corvette GS rims 19x9.5 and 19x12
Sphon offset LCA for wider tires
Burkhart chassis abs delete
Beefed up Gm truck 250 amp alt
