Only making full boost uphill under load. Why???
Old Oct 8, 2018 | 06:28 PM
SiskMan's Avatar
Default Only making full boost uphill under load. Why???
Ive been fighting with this boost issue for a little while. 3rd gear on flat road it will make 8-9 psi. Uphill it will make 12-13 psi. Waste gate has a 13 psi spring installed. Not sure what to check. At a local dyno night i had to brake boost it to make 10 psi.
Speed Daddy Ebay 44mm wastegate with a new diaphram bought separately. i tested it with my air compressor and it seemed to open around the right PSI (my regulator doesnt have great resolution.)
VS Billet 78/75 turbo
6.0
243 heads
~10.5:1
3.55 gears
camshaft https://www.howardscams.com/hydrauli...cams-190325-12
I took the reference off the gate, and it will spool instantly to 15 psi + by 3500 rpm before i let out. I understand the 13 psi spring doesnt mean ill make 13psi, with backpressure and all that. It depends on the efficiency of the setup.
Do i need more spring? If so, why does it make the correct 12-13 psi going uphill? I understand backpressure and all that makes the gate open at a certain point, not exactly at the rated spring pressure (13 psi in this case). I dont want to put more spring in it, then be going uphill and make even more boost on top of that. I tried compressor referencing the wastegate as well as referencing off the intake. No change.
Any ideas or suggestions? I'm sure its just my inexperience. Any help is appreciated. Ill attach log files and tune files.
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpt
Old Oct 10, 2018 | 10:28 PM
SiskMan's Avatar
Bump. Combination of things? Backpressure, too small of a gate, and bad placement? Backpressure pushes gate open at 8-9 psi, too small of a gate can’t vent enough with more load going uphill, or bad placement can’t vent enough?
Boost doesn’t keep climbing when WOT uphill. It hits 12 ish psi, holds, and drops slightly at high rpm. That’s what makes me think the gate is ok. Just not sure why it doesn’t build boost on flat ground in 3rd. Don’t have many areas to test out 4th gear. 2nd gear makes 5-6 psi. Again, unhook the reference line and it will boost to 15 psi at half throttle on flat in 3rd. So confusing to me.
let me know if you guys have any ideas at all. Ordered a low resolution air regulator to see exactly what psi makes the gate open with 13 psi spring.
Old Oct 11, 2018 | 04:00 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Is your reference off the turbo housing or the intake manifold? This could be diagnostically significant.
Old Oct 11, 2018 | 07:11 AM
SiskMan's Avatar
ive tried both with no noticeable change. Right now it's referenced off manifold. 6 speed car btw. Full weight. More details in sig
vacuum tested all lines. Boost leak tested cold side. Smoke tested intake. All good.
Old Oct 12, 2018 | 05:01 AM
Ben.'s Avatar
It's not a rear mount setup, is it?
Old Oct 12, 2018 | 08:48 AM
SiskMan's Avatar
Nope just your typical front mount truck manifold setup. If the weather gets nice im going to take the spring out of the gate and see how much boost it makes, if any. That will give me more info
Old Oct 12, 2018 | 09:10 AM
JoeNova's Avatar
Restricted User
Too many factors to make a real determination. You're juggling load, exhaust volume, crack pressure, backpressure, etc.
Typically, you'll almost always run less boost than what you're spring is rated for due to crack pressure and backpressure. With a large enough gate, it wouldn't have to fully open to bypass enough exhaust to keep boost from increasing. A 60mm gate only needs to open 40% to bypass more exhaust than a 38mm will fully open. The spring will begin to compress before its rated pressure, and you'll end up with less boost. Running the wastegate reference on the compressor housing makes it worse, as you'll see more boost there than in the intake (with an intercooler), so it'll open another couple of pounds less.
It could be that the up-hill boost is normal, and that the flat ground boost is reduced from the wastegate cracking open early and bypassing enough exhaust to prevent boost from climbing. The reason it wouldn't do this up hill is the increased exhaust volume still being enough to maintain turbo spool even with the gate cracked open. A manual ball/spring boost controller will fix this. You can set it so that you don't run any more boost than normal, but it'll prevent boost pressure from cracking the wastegate open too early.
Unfortunately, it could be 3 or 4 other things as well. At this point you're asking for theories. A backpressure gauge will be the only thing that can narrow it down.
Old Oct 12, 2018 | 12:13 PM
SiskMan's Avatar
Great explanation. Thank you for this.
Old Oct 12, 2018 | 04:18 PM
Bazman's Avatar
Has that turbo ever spooled well so this is a problem that has recently surfaced, or has it been like that from day one? If so - what is the turbine AR? Maybe a smaller AR would fix it??
Old Oct 12, 2018 | 05:04 PM
SiskMan's Avatar
It spools almost instantly at half throttle any rpm with the reference line unhooked. Its a .96 AR i think. VS Billet 78/75.
Sounds like i need a electronic boost controller. I was watching videos on the AEM truboost and you set the controller to your wastegate spring pressure, and it keeps the solenoid 100% open on the top of the gate until you reach that manifold pressure. then the boost controller takes over to regulate boost. They showed how a turbo would be laggy without this function enabled. Sounds exactly like what i need to help cure this problem. It would stop the waste gate from cracking open until the desired boost level was met. Like i said, it was probably my lack of experience. Thanks for all the replys.
Old Oct 13, 2018 | 04:20 PM
Bazman's Avatar
That sounds definitely worth trying. I run an e-Boost2 and I'm convinced it also cracks the valves prematurely (not as bad as your though) then shuts allowing a 2psi spike right at TQ peak where you do not want it (detonation territory). I'm going to get a better boost controller
Old Oct 14, 2018 | 09:55 AM
StreetTuned's Avatar
When you bench tested the wg with your air compressor could you hear air leaking through the gate before the valve cracked open? I’ve had a similar issue in the past with a leaky turbosmart hypergate, it caused slow turbo response. Funny enough I swapped it out for a $60 speed daddy gate that did not leak when bench tested and it fixed my issue. I’d suggest taking the wg apart and inspecting everything and make sure it doesn’t leak when bench tested.
Old Oct 15, 2018 | 07:29 AM
SiskMan's Avatar
Good idea. However, ive done this multiple times. No leaks with pressure or vacuum, it holds pressure/vacuum for a good while. Seems to open right at the suggested 13 ish psi spring pressure. And mine is a speed daddy gate as well!
Old Oct 15, 2018 | 07:31 AM
SiskMan's Avatar
From watching their tech videos you should be able to adjust that correct? with the spring pressure setting in the boost controller. They say to adjust it up/down until you get no spikes or oscillations in boost.
Old Oct 15, 2018 | 02:06 PM
8.Lug's Avatar
You clearly don’t understand how a turbo system works. The wastegate doesn’t vent to increase boost, it vents to DECREASE boost. If the gate is too small, you will get more boost or “boost creep.” The wastegate is to allow exhaust to bypass the turbo - that's why it’s mounted before the turbo. Your total confusion on how this works is probably your problem.
Old Oct 16, 2018 | 03:36 PM
SiskMan's Avatar
Yes i understand the wastegate allows exhaust to bypass the turbine. Thats why its called a waste gate, not a boost gate. Sorry if i worded it in a confusing manner. The issue has been solved with a electronic boost controller with the spring setting set to just below the crack pressure. It now hit full boost, as if the reference line was disconnected, and then the eboost2 solenoid takes over to regulate the boost from there.
I fabbed the system myself, not that im bragging. Just saying I understand how it works. Sorry if the question was worded in a way that was difficult to understand. Thank you for your concern and your reply.
Old Oct 16, 2018 | 04:44 PM
Bazman's Avatar
lolz, classy response to somebody who didn't even comprehend the thread. Well done mate, good work.
Old Oct 16, 2018 | 04:53 PM
gsteele's Avatar
I understand what you are saying but at the same time perhaps you could explain the sentence I put in bold font?
Old Oct 16, 2018 | 06:45 PM
Bazman's Avatar
LOL, yep... ok, got the point now. I had read the entire thread and understood what he was trying to say, so overlooked that bit.
Old Oct 16, 2018 | 07:05 PM
SiskMan's Avatar
yes i see I might not have been 100%clear. I was suggesting that backpressure was pushing the gate open early combined with either:
A) not a big enough waste gate to vent adequately, causing creep
B) bad wastegate placement causing creep
