To the boosted guys that have had a engine failure
.That's why I don't say "Street Car" in my sig. I say "daily driver" because the car is driven to the grocery store, then to work every day and then to the track. Same tires, all glass, heat, defrost.... you get the point.
I built one trailer queen and really didn't enjoy the experience. Got rid of that and now I'm back to building a car I can cruise with the GF and drive almost 2 hours to the nearest track.
So.....you mean..like drag week arent street cars ? :O lol
The whole street etc debate is silly...and the vast majority of such cars, there is **** all street or street legal etc about them. They're probably only "legal" in places there are no actual checks whatsoever, and nobody gives a **** about what laws there may be
something I can get in. Go to work. Has ac and heat. Wipers. And you can get caught in traffic and it don’t overheat. Get caught in the rain like this (took this pic at lunch for you guys when I left the gym) and not worry about it. Get on the interstate and drive 70-80 for hours straight (just made a road trip weekend before last to Mississippi) In other words I can drive the car whenever and wherever I want. What power does it make? I dunno yet but over 500rwhp shouldn’t be out out the question. I’m currently in boost raising mode right now, trying to get it dialed in on maybe 10lbs and leave it alone. It should end up around 550-600 on 10lbs and I can drive it anywhere. Then I’ll get a good boost controller for boost by gear. My plan is not a drag car. But a street car like we are talking about that will at least run in the 10’s but not give up anything to do it, and on pump gas without any special peripherals (e85, no’s, meth, icing the intake etc etc. Pull up at the track on radials and do nothing but a burnout and run the times. In other words like a new zr1 vette but about 100 grand cheaper. Lol.
As for streetable, while I added a cage and bulkhead behind the front seats (turbos are where the rear seats used to be), the drivers and passenger compartment still has sound deadening, stereo, air con and heater. I can and have been stuck in rush hour traffic, it'll idle at walking pace on the flat no throttle. But most would consider it a race car, and to be fair it really is - mainly because of the race seats and harness that make looking hard left or right at intersection a painin the *** - I have to loosen off my straps to lean forward. All because I need a HANS device when in events, so the seats wrap around my helmet.
As for diminishing returns as you go up in power, **** yeah... it's like a dam that springs 1 leak, you plug that one, and another pops up, you chase that game until you've got a new dam. Up until the 500's rwhp car was like stock. From 600+ up it's got expensive and now I'll need to forge the motor unless I wait for the pop. Fortunately I've done the trans, clutch, driveshaft, the diff is rated at 550kw and I exceed that at the crank so rather than spend 4 figures upgrading to a Ford 9" center I'm going to rebuild, super finish the gears, add a high tech dry coating, and run the most expensive synthetic oil I can find and then change it EVERY event. Hopefully that works, it works for Subaru's that also have weak diffs.
well I change the rules for you then, e85 is allowed. Lol
i personally don’t run it because we only have one station here. So it’s reserved for racecars mainly. I don’t daily my gto but I dondrive it 2-3 times a week. I’m trying to keep the miles off of it.
Do I have to drag up old pictures of my old turbo daily drivers?
I recently pulled my plugs and number 2 was glazed. Car shows no other signs of issues. A friend thinks my excessive amount of idle time in garage to run out the last bit of fuel to work on the fuel system may have even caused it. I’ll be sending the injector to get checked for piece of mind.
