To the boosted guys that have had a engine failure
Old Oct 16, 2018 | 11:46 AM
  #61
LSswap's Avatar
Originally Posted by BCNUL8R
started at 8 psi, then 10, now going to 12 and haven’t hurt anything yet although I know it’s coming lol.
A road well traveled by many!
Old Oct 16, 2018 | 12:08 PM
  #62
Kfxguy's Avatar
Originally Posted by LSswap
You're not giving yourself enough credit. 650 rwhp is a great accomplishment. 10s is a great goal for a daily. You're not simple. You picked and chose what to complicate and what not to complicate. That's not easy.
well I guess in this day and age of all these 1000hp cars, I feel like my 650 goal is pretty peonic (as in, I’m a peon compared lol).
but you are right!
Old Oct 16, 2018 | 12:11 PM
  #63
LSswap's Avatar
but you are right!
Those guys with the 1000hp are looking at the 1500hp guys and saying what you are saying.
Those guys with the 1500hp are looking a the.......... I could go on and on.
Old Oct 16, 2018 | 05:53 PM
  #64
ascastil's Avatar
but you are right!
I feel exactly the same way. I'm shooting for 620ish and feel like I am so far behind. A few years ago I had 500 and even then I was behind. 1000hp cars
seem like a dime a dozen now, but I've been told 600 is the best for street cars anyways. Oh well.
Old Oct 16, 2018 | 06:12 PM
  #65
stevieturbo's Avatar
6-700 will make for a great and still pretty safe street car.
Putting much more than that to effective and real use in a genuine street car is difficult.
Old Oct 16, 2018 | 06:13 PM
  #66
truckdoug's Avatar
Unless you have a very good boost by gear/rpm set up and some sort of traction control strategy, 600 wheel is plenty. Probably even too much honestly.
I can't tell the difference in the way 600 vaporizes tires and the way 1000 does.
Old Oct 16, 2018 | 06:18 PM
  #67
You should be able to put 600 down pretty well. Maybe not 1st or 2nd ( manual ) but certainly anything beyond that on a dry road with decent tyres.
Old Oct 16, 2018 | 06:19 PM
  #68
pdxmotorhead's Avatar
I've spent quite a few years at the track road racing,, Karts and Cars, For many years I traded running one of the supply trailers at the track of seat time a car..
Sold thousands of gallons of various octane and manufacturers race fuel,,, Something I learned about plug reading from a Race Fuel Chemist,,
you can't fully trust color on race gas.. The additive packages can create a
false coating on the plug that will make it look fat or lean when it can be the
opposite.. And the packages can change every shipment of fuel.
Pure white ,, or wet black yea,, but comparing light grey to off white,, not so much,
electrode bridging, burning off etc,, thats obvious, but by the time the
color of the plug truly sets,, there is plenty of time for other stuff to go sideways,,
100% methanol gives the easiest read, or 100LL Avgas, they are both almost pure
products with very few additives that will mess things up..
I used to run a car that had 8 thermocouples, that went to a box showing the hottest by default
or could cycle through the readings,, was a nice setup cause it was quick enough to give a red
light of one jug went hot or cold. $$ to get it but it was kinda cool. Was an aircraft gadget..
We still had a Wideband on there.. And yes sometimes after the fact,, it told you that the
reason the engine quit running and made expensive noises was a bad mix..
Just pondering..
Old Oct 16, 2018 | 06:41 PM
  #69
truckdoug's Avatar
I've found that the price for being wrong about that can be pretty high. Higher than I can afford at this stage in the game at least.
Old Oct 16, 2018 | 08:27 PM
  #70
Kfxguy's Avatar
yea I feel you, 1000hp cars are the norm. But can they put that down. I watch a 1000hp (demon or hellcrap) rave a 600hp car and the 600hp car handed it to him. I don’t know where I’m at right now but it’s probably at least 500+ and anything under 45 and they are going to spin. I almost lost it in traffic once. I will be getting a good controller here soon. Probably an eboost2.
Old Oct 16, 2018 | 08:31 PM
  #71
Kfxguy's Avatar
I just want to say, I enjoy shooting the **** with you fellas!
Old Oct 16, 2018 | 08:34 PM
  #72
Bazman's Avatar
A lot depends on tire and setup. At 663rwhp I could go WOT from a dig if I rolled off the clutch smooth and then floored it. In the wet I could go WOT from the top of 3rd gear. That's with a 6sp manual and 3.9 gears, but not normal tires lol. I run Nitto NT01's 315 on rear 100 compound, and they stick wet or dry once warm.... unless there's standing water..... then it's really really bad. haha.
Old Oct 16, 2018 | 08:39 PM
  #73
Bazman's Avatar
Haven't popped motor yet but have worked it hard and got it f#4!'n hot a few times. Down 15psi on 1 so will build it and forge it. Could easily go for 1000rw and might as a one off thing - but feel 700rw is the sweet spot for my car. Less if I went to normal road tires. The biggest safety feature on our modern cars are the trutrac type diffs. The old lockers/spools, mechanical LSD's are lethal on public roads at our power levels because there is no steering except by throttle when they lose it. The trutrac/wavetrcs etc are legend at helping the car stay on the road even spinning up.
Old Oct 16, 2018 | 08:42 PM
  #74
LSswap's Avatar
Stay safe fellas.
As you increase the power, usually the next weak link breaks. This is also true for your tires.
I chose very tall drag radials with 15" wheel. May not be stylin, but i'm hoping they will hook.
Old Oct 16, 2018 | 08:54 PM
  #75
Kfxguy's Avatar
i can roll into mine but if I get over 4-5lbs boost, that’s it. Tires are spinning. First gear is useless on the street even with drag tires. I can spin the drag tires (well they aren’t anything special, fresh nto5r in 275 wide) at 35 in second. The turbo builds so much tq. I don’t do that usually. That loads the motor too much I think.
Old Oct 16, 2018 | 09:00 PM
  #76
Game ova's Avatar
1000rwhp cars are NOT the norm. We just get lulled into thinking they are, because we hang out on here, and 1320 video all day.
Old Oct 16, 2018 | 11:22 PM
  #77
5.7stroker's Avatar
For the guys running the 427 LSX Dart or Bow Tie blocks with twin 7875's or similar putting down 1300+ using the 4L80E's to keep over drive for a 'street setup' heavy car while still running 8's at the track on your trans brakes, what gear ratios are you using? Standard 2.48 for 1st and 1.48 for 2nd? Assuming the suspension is all dialed in with all the aftermarket goodies to properly hook, how far are you dropping the power on the street such that the car can be handled with say a pair of MT ET streets? What axle ratio is common in these setups? 3.25? 3.42? What stall speed? This combo has been around for awhile now and I'm considering such a build, just curious on what some of the more common street setups are at that power level.
Old Oct 17, 2018 | 03:12 AM
  #78
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Those NT01s are no different from most race tires, however. If you get on them when cold you will feel like you are ice skating. I once left the track on MTDRs and decided to swap on the NT01s at the gas station right at the interstate. Accelerating onto the interstate I damn near went sideways when I did a no lift shift into 4th gear. With a little heat in them they would have barely spun popping 2nd gear.
Old Oct 17, 2018 | 03:55 AM
  #79
BCNUL8R's Avatar
^This...In my town of about 12,000 people there are a surprising amount of 1000+ horse "street" cars because we have an 1/8th mile track here where no prep racing is big. You never actually see them driving around town though. I can drive my maybe close to 600 rwhp car around and no one tries me. When I go to the "street drags" at the strip I'm literally the slowest car there as I drive in a daily capable car while everyone else comes in on trailers. I only won one race at the track this year and that was against a new unsuspecting Mustang that was most likely new to racing.
While there are daily capable cars over 1000 rwhp they aren't as common as the internet makes them seem. The definition of a street car has changed a bit over the last 10 years. Most of the cars you see at the "street drags" or no prep races are never driven on the street. With that said my close friend runs 5.1x with a 2002 corvette and has driven it to and from the track just to prove a point before. I will also mention from hanging with him that the "no prep" events by the second round actually hook better than the regular prepped races here. People put down so much prep that by the second round guys are struggling to keep the front end down. No prep has changed a lot he runs his best ET's and 60' on no prep events that should tell you something. Now they've even moved to a pro tree from a instant green. It's really benefitting the huge power cars more now than ever.
One thing about the centri is it's easy to control. I know I'm only about 600 with an auto, but the linear curve with less torque than a turbo makes it easier to drive on the street.
Old Oct 17, 2018 | 04:44 AM
  #80
Game ova's Avatar
I agree with this^^^. Even on this forum, the term "street car" has been stretched beyond recognition. Many of them are nothing more than hacked to death race cars that get driven on the street. There's a night and day difference between those..... and a genuine real deal street car.
