To the boosted guys that have had a engine failure
Old Oct 15, 2018 | 03:13 PM
  #41
ddnspider's Avatar
Originally Posted by ascastil
Me neither. I told my wife one day that I saw an ATS and it looked like a pretty nice car. My wife being a go fast car chick said to me all excited "did you know they come in a V?" I looked it up with her and a year later I bought one for her. Was not disappointed lol.
Good to know. i remember reading 0-60 in 3.8 and went WTF???
Old Oct 15, 2018 | 03:34 PM
  #42
Black_Sunshine_99's Avatar
My buddy has an ATS-V and it blew my mind with how well it handles and the power that little TT V6 makes.
Would definitely own one.
Old Oct 15, 2018 | 04:04 PM
  #43
Kfxguy's Avatar
Originally Posted by 47ford
not meant to be a back hand it’s just a fact? I’ve been through a few setups and no matter how many sensors you have the plugs don’t lie. I switched to efi this year and was having some issues ..... Long story short you have to revert to reading those plus even when sensors are reading “correct” just to be sure... Everytime i even have a slight issue i’m always asked what the plugs look like.... Haven’t dove into ethanol tuning but when i do, no matter how hard it is, i will learn to read those plugs too.
To the part of plugs being hard to get to and higher compression. If you can’t tune on higher compression run lower if you are not a wiz at tuning? If your plugs are hard to get to you didn’t think hard enough about your set up. my #1 priority on my hot side was using stock plug wires and ease of access to the plugs.
this.
Old Oct 15, 2018 | 04:07 PM
  #44
Kfxguy's Avatar
While it absolutely help tuning, reading plugs is still an after the fact action that wont save an engine if it leans out during a pull for various reasons. Agree that reading plugs helps with the tuneup but its not uncommon for things to change so if you see your wideband go lean during a pull its easy to lift rather then pick plugs up off the street. Pumps die, filters clog, injectors fail, boost spikes, voltage drops, etc..
This is exactly what i'm talking about. Well said.
Old Oct 15, 2018 | 04:09 PM
  #45
Kfxguy's Avatar
Originally Posted by Game ova
If you are staring at a wideband, even in an 11 sec car....you're a fool. But yes, my junk has seen 10s, nice jab btw.
what are you talking about? Haven't you ever heard of the "stare and drive"?
Old Oct 15, 2018 | 04:11 PM
  #46
Kfxguy's Avatar
Nobody is saying to stare at it, but a quick glace is completely reasonable unless you can't walk and chew gun at the same time.
LMAO! Truth!
Old Oct 15, 2018 | 04:13 PM
  #47
Game ova's Avatar
Sure have.
Old Oct 15, 2018 | 04:14 PM
  #48
Kfxguy's Avatar
That'll hardly help in the scenario mentioned, or countless other real time events.
A wideband is a critical piece of information, but it can also be affected by other things, mis-interpreted or simply not enough information.
And a glance when driving is usually enough, but of course for proper monitoring that's what datalogging is for. In which case the more information you can gain the better.
yes. yes. and yes.
Old Oct 15, 2018 | 04:17 PM
  #49
Kfxguy's Avatar
Sure have.
well obviously that driver didn't know how to do it very well.
Old Oct 15, 2018 | 10:53 PM
  #50
Bazman's Avatar
:lolcry: yeah, you were thinking more of the other drivers that stare and drive, not that one so much
Old Oct 16, 2018 | 03:46 AM
  #51
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Not meant to be a back hand it’s just a fact? I’ve been through a few setups and no matter how many sensors you have the plugs don’t lie. I switched to efi this year and was having some issues ..... long story short you have to revert to reading those plus even when sensors are reading “correct” just to be sure... everytime I even have a slight issue I’m always asked what the plugs look like.... haven’t dove into ethanol tuning but when I do, no matter how hard it is, I will learn to read those plugs too.
to the part of plugs being hard to get to and higher compression. If you can’t tune on higher compression run lower if you are not a wiz at tuning? If your plugs are hard to get to you didn’t think hard enough about your set up. My #1 priority on my hot side was using stock plug wires and ease of access to the plugs.
Your response to my comment leads me to believe you put a lot more thought into your builds than some people here. There is a steep learning curve to this sort of work, and most newbies try to skip some steps. The results are generally blown motor threads.
Old Oct 16, 2018 | 09:06 AM
  #52
LSswap's Avatar
Spend the money on Wideband, fuel pressure and knock logging.
Doesn't mean that you can ignore good practices. For example, I burnt through a piston probably because of an alky mist system failure at 28PSI. Wideband log told me after the piston was toast.
Old Oct 16, 2018 | 10:07 AM
  #53
Kfxguy's Avatar
see I like to keep things simple. Examples.
I don’t like nitrous. Because you have to rely on filling a bottle.
I don’t like meth injection. You have to fill the bottle and you could have a system failure. Then you have a motor failure.
I don’t like e85. Because I have to find special stations to get fuel.
I guess im just a simple kind of guy. If I can’t make the power I need to go as fast as the goal I may have, I start getting ingenuitive. I start looking at ways to free up friction. Lighten things up. Make things more efficient.......oops, I’m getting off topic. Lol.
Old Oct 16, 2018 | 10:32 AM
  #54
tblentrprz's Avatar
Anyone using their ECU to monitor key parameters with safety limits?
Old Oct 16, 2018 | 10:40 AM
  #55
jimmyg's Avatar
I have a mast ecm . I really like they way they set it up . Any knock it will pull timing. One time I had a suspect tank of gas, and it would pull 6* of timing @ WOT. I have fuel pressure, wideband, and a boost gauge on the pillar. Everything else I can see on my laptop. I usually keep an eye on actual timing and IATs
Old Oct 16, 2018 | 10:44 AM
  #56
stevieturbo's Avatar
Those who have sense and a capable ecu are.
Old Oct 16, 2018 | 10:48 AM
  #57
BCNUL8R's Avatar
Exactly why I like to use E85 with a single large external fuel pump. No second pump or meth pump to worry about failing. I’m new to tuning myself started at 8 psi, then 10, now going to 12 and haven’t hurt anything yet although I know it’s coming lol.
Old Oct 16, 2018 | 11:05 AM
  #58
LSswap's Avatar
Generally, I agree that simpler could be better.
However simple is great if it meets your goals. For example if your goals are to get groceries, a stock, N/A, ford focus is simple. Forced induction by definition is not simple.
If your goal is to run 6 lbs of boost, then you've already chosen to complicate some things like turbo setup, wastegates, boost control, AFRs, tune etc, but you can still keep the pump gas simple.
If your goal is to run 28 lbs of boost in a daily driver, then you need a little more complexity (e85 not available everywhere).
Old Oct 16, 2018 | 11:24 AM
  #59
Kfxguy's Avatar
yes im simple. 650rwhp for me is plenty. I’m just looking to run in the 10’s and be able to drive it anywhere. I’ve got the anywhere part down. Running in the 10’s, well I gotta get to the track and see. I’m on 6lbs right now but I turned it up a little last night. Trying to get to 8-10 and leave it alone. Im not working with an unlimited budget or time so I need this engine to last until I put a built one in. I don’t have time right now either to be swapping engines. I have a aluminum block 5.3 that’s complete, that I have to go through and put rods and pistons in and a few other little things. Then I should be able to lean on it more. Or not. But have a bigger safety margin
Old Oct 16, 2018 | 11:33 AM
  #60
LSswap's Avatar
You're not giving yourself enough credit. 650 rwhp is a great accomplishment. 10s is a great goal for a daily. You're not simple. You picked and chose what to complicate and what not to complicate. That's not easy.
