Boost And Timing
Old Nov 3, 2018 | 02:19 PM
TrendSetter's Avatar
What do the plugs look like? Stock cam and ~9:1 CR?
plugs arent bad, i just had them out. distribution isnt great, #6 is the leanest. plugs are in order in the picture and have many thousand miles on them. they are tr8s
im constantly moving the tune around and ive never been to the track or dyno. its an awd pickup so the dyno isnt really feasible plus im too cheap for that kind of expense.
I drive the truck a ton and the plugs are a real pain to get out, but i need to get off my *** and read them if im so insistent on continuing to raise the boost.
its about 9:1 and cam is the cheapy elgin 220/224 112 lsa 108 icl. i ported the 5.3 heads and it has a tbss intake on it.
Old Nov 3, 2018 | 02:26 PM
MY_2K_Z's Avatar
Can't read those plugs. You need to make a pull and shut it down and pull your leanest plug
Old Nov 3, 2018 | 03:24 PM
youre right.
Old Nov 3, 2018 | 06:13 PM
ddnspider's Avatar
If you clean off the threads you'll at least be able to see how much heat is on the threads. An 8 is pretty cold with that low of timing. If you wanna mess around 1 day hit me up and we can swap your hottest plug and log.
Old Nov 3, 2018 | 06:24 PM
MY_2K_Z's Avatar
Ya on those boost levels a tr6 would even do it I think.
Oops misread the post
Old Nov 3, 2018 | 06:43 PM
22 psi on 93 and you would run a tr6?
ive read a decent amount and maybe i missed something but i rarely see anyone mention going more than 18psi on straight 93 and they are in the 10degree timing range.
I was running 32 on 93 in my evo but thats quite a different animal and hard to compare to timing wise.
i agree i need to do the proper plug reading stuff but i simply havent found the time yet. im basically ready for the track hardware-wise so i think you guys have given me the motivation to order up some plugs and spend some time with the shitbox.
Old Nov 3, 2018 | 07:19 PM
ddnspider's Avatar
Hell no. Way too many people run to hot of a plug when going 1 step colder gives you more margin against pre-ignition and usually only costs a couple hp.
Old Nov 3, 2018 | 07:43 PM
i error on the cold side. very little downside in my experience. i put hours and hours of 15-16:1 cruise on tr8s no problem.
Old Nov 3, 2018 | 08:15 PM
ddnspider's Avatar
An 8 is pretty cold but that's alot of boost on pump. I've had no issues with 7s. Plenty of people say they foul them and their car ran like crap, but I assume either the gap was wrong or they can't tune.
Old Nov 3, 2018 | 09:14 PM
MY_2K_Z's Avatar
No I was think you were kfx he just posted saying 8-10psi so ya Hell no on 22psi lol
Old Nov 3, 2018 | 09:54 PM
MY_2K_Z's Avatar
You are correct I thought kfx was op. I'll edit my post.
Old Nov 3, 2018 | 11:15 PM
  #32
truckdoug's Avatar
off topic but hey, what do you guys run in your NA ls motors?
Old Nov 4, 2018 | 06:58 AM
  #33
depends on compression. id probably run at least a tr6 in anything that wasnt a stocker, but like i said, i error on the cold side.
ive used everything from tr6s to 5671-10s in a variety of pump gas motors and havent ever really had fouling issues. the only real problem ive seen with plugs is my stupid evo has to use iridiums with little baby dick electrodes and ever since i swapped d585s on it the electrodes erode away and the gap opens up a bunch
Old Nov 4, 2018 | 07:17 AM
  #34
ddnspider's Avatar
Ah makes more sense now.
Old Nov 9, 2018 | 11:10 AM
  #35
rpturbo's Avatar
You do know there is more to reading plugs, than just the color, right? You can see the timing mark on the strap when you look close. I always use some good reading glasses to really see what's going on.
Old Nov 9, 2018 | 11:24 AM
  #36
yes i know that.
those plugs have a ton of miles on them, and the picture was taken a few weeks ago for a different reason.
i only posted them because someone asked.
