What's your engine cost?
Old Jul 12, 2004 | 10:24 PM
NA$TY-TA's Avatar
You can get a AP Engineering 408 for around $8K for the longblock.
Give them a call
Kyle
Old Jul 12, 2004 | 10:58 PM
buschman's Avatar
Originally Posted by BOOSTAT4500
Out of curiosity, what do you want that is gonna cost $12-13k for just the motor? Are you wanting a C5r or something? Just seems kind of high is all.
I want to go the darton mid-sleeve LS1 route. I'll quote my engine builder:
Originally Posted by Stephan Demirjian [race-engine-development@***.net
] Crank, rods, pistons, rings, bearings will run at least $3K. That would be a kit from Callies or Lunati. I would not use their rods however at that power level. So you would end up purchasing a Lunati or Callies crank, Crower or similar rods, and a set of blower pistons from J&E or Ross, etc. That $3K now becomes $4K. So we are at $8K with a sleeved align honed steel capped block.
I was figuring AFR heads into my pricing. If you are going to use your current heads then the price would be reduced. But we still need a camshaft, roller lifters, pushrods, probably springs and touch up of your heads, set of adjustable rocker arms not the non adjustable junk most guys try to get away with. That will add another $2 - 2.5K to the above pricing bringing it to $10 - $10.5K with your heads. You will need gaskets, fasteners, a good balancer, a new oil pump and associated parts like new pickup tube and so on - figure another $500 - $600 for these parts. I assume you have an oil pan, front and rear covers, valley cover, etc. we can use off your current engine. If not I'll have to come up with those pieces. I have not yet priced in any labor to assemble the engine or balance the crankshaft assembly. Assembly includes cleaning all the parts, deburring, checking clearances and adjusting as required with over under bearings, gapping rings, degreeing camshaft, getting rocker arm geometry correct, (not just the pushrod length but the installed height of the rocker arm stands), etc. My normal charge is $1K for assembly on this type engine and between $200 and $300 for balancing not including heavy metal if required, depending on time involved. Add this up and you are up to $12K using your current heads. Michael, this is in no way a money maker for me as it will take the better part of a week to properly assemble an engine. I make more money in a day machining a block for sleeves.
Someone I'm sure will do it cheaper but not better. If I do a job I do it right or not at all. I do not cut corners on parts or labor to save money. It always ends up more expensive in the end doing things that way. I have two short blocks coming in to repair that guys had done by hackers elsewhere to save money.
From talking with Steve, I believe he can build an engine capable of doing what I want it to do. But saving for a house makes dropping $12-13K on an engine a lot to swallow.
Mike
Old Jul 13, 2004 | 04:43 PM
Bryan Wilkinson's Avatar
Originally Posted by buschman
I've been playing around with the idea of replacing the engine this winter. But I came up with a dollar amount and found out to do it right was gonna cost double what I had alotted. Just curious what kind of change you guy dropped on your engine and if you were happy, what you liked, what you didn't, and so on. If you're willing give me a dollar amount and what you got for it. Then your reaction to the setup.
Thanks,
Mike
Mike,
I have around $40K tied up in mine.
Old Jul 13, 2004 | 09:38 PM
buschman's Avatar
Originally Posted by Bryan Wilkinson
Mike,
In just the motor? How could it get that high? I know the C5R is priced high, but wow!
Mike
Old Jul 13, 2004 | 10:17 PM
BOOSTAT4500's Avatar
Is $4k normal for just the block? I thought they were around $2200. Or is that without any machine work? Now I'm really glad I went the iron route ( $1200 with machine work, or $600 if you have a good core )
Old Jul 13, 2004 | 10:24 PM
buschman's Avatar
That's for the Darton mid sleeved block. A lot of machine work goes into it. But from what I understand it's as strong as you can get. But I'm no expert, still learning.
Mike
