Cortex boost by gear EBC electronic boost controller
Well once I got past that, I decided to start installing this past weekend. It was actually extremely simple to install. Christopher at cortex sent me the links I need for my install. They actually had direct instructions and setting needed for my gto. No guesswork there except on dialing in the speed detection and gear signal. Easy. Go for a drive and log the eve number it shows while your in each gear. Plug those numbers in an bam. It knows what gear your in. So I finally got to drive the car tonight because its been raining. Once I figured out that I needed higher duty cycle numbers than normal because of my 4lb spring, it worked like a champ. First gear I could keep it under 2psi and then it ramped in in 2nd as soon as I shifted. Im really liking this. Its time to up my spring now!
So basically what you can do is set your desired pressure for each gear. Thats using the basic setting. You have other options. Another neat one is the rpm vs tps. You can set boost at whatever rpm you want it to come in and what throttle percentage. Each gear has its own settings. Has overboost protection of course. Im not even scratching the surface of what it can do in my car, but its alot of different options. If your looking for a boost controller that does real boost by gear, this unit is definitely worth checking out. Im going to try and get some video of it for you guys. In the meantime heres some pics
What comes in the box
Display. It does light up red but Im getting a green one made to match my gauges
Heres the control box
Plugs right into the VSS input. Requires some recalibration in the speedo section. Works great.
Very hard to find though.
Ron
boost
rpm
tps
gear your in
afr
to name a few
You give it a speed signal, tell it your gearing and from rpm and speed it will know what gear you're in.
Although with an auto, it may not be so clear cut if there is TC slippage involved.
it said that in the destructions. But what I did is cruised in 1st gear, noted the number and rounded it to the nearest 10. Which was 52 it was showing so I put 50 in. Then in second I did the same thing. Ended up with 30. 3rd was 15 and fourth was 12. Evidently that worked because I can put the display in gear mode and it’s picking it up like it should. And I stomp it, little to no boost in first gear and immediately starts boosting in second. You guys just don’t know how excited I am. This is going to help greatly especially since the best tires I have right now are nitto nt05r
That's fantastic man, sounds like a great device. Can't wait to get this thing together and get one. I'm going to run around on 315/35r17 Toyo R888Rs as my street setup for most action so it'll be nice to bring the power in as the tires can handle it even with just 3 gears.
