How much power does your setup make on 91 octane?
Old Nov 11, 2018 | 07:19 PM
krazy4's Avatar
Default How much power does your setup make on 91 octane?
Putting together a pump gas small single turbo motor.
What do your cars make on 91 octane only with no methanol?
Would love some info on boost pressure and ignition timing if you have it.
Thanks!
Old Nov 11, 2018 | 08:07 PM
93hatch's Avatar
itll make a cracked ringland
Old Nov 11, 2018 | 08:31 PM
truckdoug's Avatar
I felt safe at 7 psi and 11* on pump no meth, bref7 plugs
Old Nov 11, 2018 | 10:01 PM
krazy4's Avatar
Depends on lots of factors.
Thanks for the input. Did the timing mark look good on the bref7 plugs or were they too cold?
Old Nov 11, 2018 | 10:22 PM
truckdoug's Avatar
they looked good and safe.
Old Nov 12, 2018 | 06:43 PM
yenkomike's Avatar
I ran 10# boost and 11* timing with my nova. no meth on 91 pumpgas car ran 10.54 @130 3500 lbs with me . 6.0 small cam tc78 turbo 350 th trans and 3.23 gears footbreaking it.
Old Nov 12, 2018 | 06:45 PM
yenkomike's Avatar
never hurt a thing. the same engine is still in the car 5 years later. and ran 9.44 on e85 last weekend.
Old Nov 12, 2018 | 06:57 PM
JoeNova's Avatar
Restricted User
Thanks!
Not as much as it would if you'd just spend $300 on a meth kit and get it over with.
Old Nov 12, 2018 | 07:01 PM
krazy4's Avatar
Thanks for the input guys.
The car will be getting a meth kit. I just wanted to see what people are doing on pump gas only.
Old Nov 12, 2018 | 07:42 PM
Photochop's Avatar
On a previous car I made 595rwhp thru a T56 & 12 bolt @ 15psi with a forged LS1 and dinky little 70mm turbo on 91 octane. Sprayed meth/water before IAT sensor and made 615rw.
Old Nov 13, 2018 | 09:30 AM
Black_Sunshine_99's Avatar
689rwhp/674tq on pump 91 with a whiff Trick 100 just for a bit of safety on the dyno, other than that it drinks pump swill only.
Old Nov 13, 2018 | 03:08 PM
krazy4's Avatar
You guys are getting some good results. Nice!
