Forged & Turbo Daily Driver
Old Nov 28, 2018 | 09:59 AM
SLOW SEDAN's Avatar
Originally Posted by Quinn23
Lol it’s an auto. Would it really blow up?
21 mpg isn’t bad for 800 horses.
I don't have much faith in the 6L80, you have to baby them and even built they don't last terribly long with decent power. Sure they will live awhile at the 600-700hp level, 800+ they aren't so fond of. I would stick with the 7675 if auto so you don't overwhelm it.
Originally Posted by fif_gen_powa
He said he wanted to run 93/e85 and a flex fuel sensor is dirt cheap for these vehicles where you can run pump day to day if you're worried about gas mileage and then fill with e85 when you want to run high boost.
Agree, flex fuel super easy on these cars.
Old Nov 28, 2018 | 10:29 AM
ddnspider's Avatar
If I can make a stock 4l60 live you better be able to make a 6l80 live. I'd go 7875 turbo, small turbo cam, small stall, flex fuel if you have e85 in the area and call it good with a good tuner. It'll drive nice, spool fast, be fun, and potentially get better highway gas mileage. My 383 turbo was pulling 30mpg on the highway.
Old Nov 28, 2018 | 11:55 AM
truckdoug's Avatar
when I see people lay down 30mpg numbers im like holy **** why do I drive these goddamn brick shaped squarebodies
Old Nov 28, 2018 | 12:23 PM
ddnspider's Avatar
T56+turbo+cubes+baby cam+3.5 gear in the 9"=70 mph cruising at low RPM and high map=good gas mileage. It was actually on the cover of High Performance Pontiac awhile back with a heading of 30mpg hahahah.
Old Nov 28, 2018 | 12:27 PM
SLOW SEDAN's Avatar
I wouldn't wish a 4L60 on anyone lol. It depends on what you call live as well as your budget. To me it wasn't worth the cost of building a 6L80 so I moved on because both a TH400 and a manual swap are cheaper and more reliable. 6L80 usually works decently until somewhere between high 9's low 10's 600-700hp but still eventually break. I know someone will say tuning is key and I've seen pretty much every tuner from this country 6L80's break built or not. Shop built trans from the likes of Century and Circle-D and home built trans with parts from PATC transmission fail as well. Some will say a 6L90 is stronger but I see 2-3 CTSV's per track day munch a trans, so while I'm sure it's possible to make them live its not worth the hassle to me especially if you want to make well in excess of 800hp.
Old Nov 28, 2018 | 12:31 PM
Game ova's Avatar
Don't you DARE mention the TH400!!. Aren't you aware that once you install a 400, you will lose 75% of your RWHP, and will lose ALL ability to drive on the freeway??!! 400S are for race cars only!
Old Nov 28, 2018 | 12:35 PM
SLOW SEDAN's Avatar
Family car TR6060, 5.3L on 28" tire you basically idle down the highway at 70 MPH. In the twin turbo vette I routinely get 25+ MPG and if I could stop getting into boost I'm sure I could see 30 but that's no fun.
Old Nov 28, 2018 | 12:41 PM
SLOW SEDAN's Avatar
While I'm not personally a fan of TH400's for a street car, I didn't lose much more then 2MPG switching from a 6L80 to a TH400. That was with 3.45 gear on 28" tire both having a fairly loose converter. TH400 was fine on the highway as well and I had a big cooler on it with a deep pan. Switching from a 6L80 to a TH400 also dropped like a second at the track, the 6L80 first gear is horrible for traction if you make any power.
Old Nov 28, 2018 | 12:46 PM
Game ova's Avatar
Well, I was being sarcastic, forgot to add the jest emoji. I'd drive mine across country, but then again I like "airplane gears" aka 2:73. The 400 isn't near as bad as most people make it out to be, as long as it's used behind something that doesn't require 6:14 gears.
Old Nov 28, 2018 | 12:50 PM
ddnspider's Avatar
I am in the camp that a stock 4L60E with the right tune will live a long time, including track abuse. Got a sticky about it, but it does the thing you hate most....limit RPM
ddnspider's Avatar
Whats the plans for the car if you're not selling it, save for a rear and run a 9?
Old Nov 28, 2018 | 12:56 PM
  #32
Game ova's Avatar
I was going to go to the track for a hail mary pass, just to get the single digit slip a couple weeks ago as the weather was perfect, then quit tracking the car. But the track closed early for the season, but I think I'm going to quit tracking it anyway, even without the single digit slip. Anymore, I just cruise around town every now and then, sits in the garage more than anything though. But to answer the question, no 9 inch is in the near future.
Old Nov 28, 2018 | 01:13 PM
  #33
JoeNova's Avatar
Restricted User
I see some ridiculous TH400 stuff sometimes.
Guy over at JackTuned posted on Facebook about his first 1000 horsepower build, because it made 680whp or something with a TH400, and that TH400 drivetrains typically see ~35% drivetrain loss. When I tried to explain it didn't work that way, he got pretty upset and started quoting people. If that's the case, my little 4.8/TH400 combo is making over 900 at the flywheel on just 11 PSI.
I think with a 3.07 of gear and 28" tall tire, mine is at like 2500 RPM on the highway. That's not too bad until you consider I have no body on the car and sidepipes with a decent sized cam. I still don't mind cruising it on the highway.
Old Nov 28, 2018 | 01:16 PM
  #34
ddnspider's Avatar
I meant a 9 as in ET not in rearend, but I got you. Breaking stuff is expensive.
Old Nov 28, 2018 | 01:21 PM
  #35
SLOW SEDAN's Avatar
Hence why I was agreeing with you that they work perfectly fine on the street
Old Nov 28, 2018 | 01:26 PM
  #36
Game ova's Avatar
Dyno before and after 400 install, same dyno...weighted the same....yadayada.
After the swap
Old Nov 28, 2018 | 01:29 PM
  #37
SLOW SEDAN's Avatar
Not many people are willing to spend the money to build a 4L60 that will handle decent power and by decent I don't mean running 11's. Throw 800+whp at a 4L60 and it doesn't last long at all.
Ya if I was stuck driving an auto with a low rev limit I may as well get out and walk... be about as much fun.
Old Nov 28, 2018 | 01:31 PM
  #38
JoeNova's Avatar
Restricted User
The numbers are impossible to see in those videos.
Old Nov 28, 2018 | 01:33 PM
  #39
Game ova's Avatar
God this is brutal . Slap in the face to all my heads cam buddies, got me all busted up in tears over here.
Old Nov 28, 2018 | 02:11 PM
  #40
Game ova's Avatar
763/891 T56
742/1045 TH400. I'll admit, torque is suspect with the 400, converter probably. I feel that as long as the converter is a solid piece, one that isn't being ran through, it really doesn't affect the power to the ground nearly as much as most think.
