Forged & Turbo Daily Driver
Old Nov 28, 2018 | 08:51 AM
Quinn23's Avatar
Default Forged & Turbo Daily Driver
So, I’m planning on getting a ‘15 SS Sedan late this year and I’m wanting to do a single turbo kit from Kozaa with a 76/75mm Precision Turbo, forge the motor ( pistons & rods ), cam from either TPS or Vengeace racing, E85/93 ( no meth ), port the stock heads, tune, and I think that would be it.
My question is, how would the car fair with daily driving and road trips? I hear forged motors use more oil and knock when they are cold. If I could forge the motor and have it drive like normal until I get into the throttle that would be amazing!
Old Nov 28, 2018 | 08:53 AM
ddnspider's Avatar
I daily drove my forged 383 turbo TA and had no issues. Why do you want to forge the motor? What power are you looking for?
Old Nov 28, 2018 | 08:55 AM
Quinn23's Avatar
I’d like 600-800+. 600 on low boost settings & 800+ on high Boost settings. I’d also like to not break a rod while pushing it.
Old Nov 28, 2018 | 09:08 AM
ddnspider's Avatar
That SS comes with an LS3 right? You should be ok with a stock motor if so.
Old Nov 28, 2018 | 09:09 AM
Quinn23's Avatar
Yep, it comes with a LS3. I’d still like to stay on the safe side and just put forged pistons & rods
Old Nov 28, 2018 | 09:19 AM
408GT's Avatar
I ran 18 psi on a 6.2 for several years w/o issue. JFR cam, S480, E85.
SLOW SEDAN's Avatar
I had a 76/75 on my G8, worked fine and spooled quick but the T4 choked up the engine a good bit at higher boost levels. I wouldn't bother forging a Gen4 engine for an 800 hp turbo setup, with a good tune and proper fuel the only one that will blow it up is your tuner. I also wouldn't bother porting the heads, LS3 flow good enough to make a lot more power then your planning.
If you feel compelled to forge the engine then get a bigger turbo to make the cost worth it.
Old Nov 28, 2018 | 09:22 AM
Quinn23's Avatar
So, at what power level would you forge the motor? I honestly liked to figure out the right sized turbo so it wouldn’t take forever for it to get boost.
Old Nov 28, 2018 | 09:24 AM
fif_gen_powa's Avatar
good info here, no need to build an ls3 for 600-800whp. turbo cam, good fuel system, e85 and good safe tune. mine has been turbo for 3 and a half years
Old Nov 28, 2018 | 09:26 AM
Game ova's Avatar
You will get sick of the horrendous gas mileage and will soon give the daily idea up, and this will happen long before you hurt your motor.
Old Nov 28, 2018 | 09:27 AM
Quinn23's Avatar
Ah, okay. So. Basically I can keep my AC & have all my creature comforts while making 600-800 horses while driving 100-500 miles? That would be amazing.
Old Nov 28, 2018 | 09:30 AM
Quinn23's Avatar
I fear that.
Old Nov 28, 2018 | 09:40 AM
Absolutely, as long as kit is well designed and all heat from the kit is well managed. My car drives like stock out of boost and not sure what that guy is talking about gas mileage... under cruise should be close to stock like as well, as long as you tuner has any clue what he's doing
Old Nov 28, 2018 | 09:42 AM
SLOW SEDAN's Avatar
20MPG is bad? Assuming he has a manual... if he has a 6L80 then the turbo gonna blow that up anyway lol
No point in e85 for 600hp and daily driving, I don't even think of E85 until over 750hp just doesn't seem worth the hassle to me.
I didn't bend a rod until I ran 30+ PSI from a T6 billet borg, and even then it took awhile. With a 6.2 it wont take many turbos long to get into boost.
Old Nov 28, 2018 | 09:43 AM
Game ova's Avatar
Before I say what I'm thinking, let me make sure of something first. Are you saying there's no difference in fuel mileage between E85 and regular fuel?
Old Nov 28, 2018 | 09:45 AM
Everyone know there is a difference between pump and e85 gas mileage, where did I say there is not?
Old Nov 28, 2018 | 09:48 AM
Quinn23's Avatar
Lol it’s an auto. Would it really blow up?
21 mpg isn’t bad for 800 horses.
Game ova's Avatar
You basically called me a lie, but whatever. You're right, I have no clue what I'm talking about.
Old Nov 28, 2018 | 09:52 AM
He said he wanted to run 93/e85 and a flex fuel sensor is dirt cheap for these vehicles where you can run pump day to day if you're worried about gas mileage and then fill with e85 when you want to run high boost.
Old Nov 28, 2018 | 09:54 AM
Quinn23's Avatar
Thats what I was going to do. E85 during high boost.
