Should it be clattering at this low boost?
Old Nov 28, 2018 | 12:33 PM
Kfxguy's Avatar
Originally Posted by LSswap
What kind of valve springs?
I dont know the part number. double ones that cam with the cam package.
Old Nov 28, 2018 | 12:36 PM
Kfxguy's Avatar
i watched the video and didn't hear any obvious knock, just compressor chop from the bov opening
thats not to say it's aint knocking though. by the time you can hear it in the car....**** is done for
so chances are ive probable damaged a piston(s)? i will say this, My car is pretty quiet and i'm very keen on hearing detonation. i never ignore it and always let off immediately
Old Nov 28, 2018 | 12:43 PM
Kfxguy's Avatar
guys, I'm an idiot. I posted the wrong video. I fixed it. you should be able to hear it now.
Old Nov 28, 2018 | 01:35 PM
truckdoug's Avatar
i dont hear nothing. but that dont mean **** really.
Old Nov 28, 2018 | 01:42 PM
3 window's Avatar
I heard it. Right at the shift recovery. Have you verified timing with a pointer and timing light? Do a leak down and compression test and see what’s up.
Old Nov 28, 2018 | 01:51 PM
truckdoug's Avatar
man my hearing must really suck.
i guess i did race a half a season with 2 spun cam bearings
"man this JY 4.8 sure is a clacker, lol"
Old Nov 28, 2018 | 02:03 PM
qweedqwag's Avatar
Originally Posted by Kfxguy
im ordering some right now. Yes I am crazy. Sometimes. I like to live life dangerously. I weld in flip flops. No sleeves and a muscle shirt.
Lol. Just kidding. Or am I? ( I really do weld in flip flops lmao)
I call the thinning the herd, thanks for that, your making room for someone smarter.
Old Nov 28, 2018 | 02:05 PM
SoFla01SSLookinstok's Avatar
Heard it that time. I'd def start with some colder plugs as noted.
Old Nov 28, 2018 | 02:19 PM
truckdoug's Avatar
yeah dude put some boots on when welding. that **** is no joke. i burned the bottom of my feet really bad when i was about 25 hardfacing a drag bucket. i was sitting on a block of wood with the soles of my boots together in front of me and I musta hit some porosity b/c it blew about a half pound of molten steel into my lap (luckily leather apron or i'd be singin castrato!) well that **** ran down onto my boots and as soon as it hit the welt it steamed the leather and cooked my goddamn feet! smelled like bacon i **** you not. i was off work 6 months and developed a nice little taste for pain killers that took another 6 months of ****** around to get right. wear some PPE ya ding dong!
Old Nov 28, 2018 | 03:09 PM
Kfxguy's Avatar
I know. I dont do it often. I onlt do it tig welding. If i stick or mig, yea I have boots on. I was more or less making a funny, I dont make a habit out of it. If im working on something and i happen to have flip flops on (its hot here in Louisiana) and i need to tack something or a minor weld, I dont put my welding gear on. lazy i guess.
Old Nov 28, 2018 | 03:15 PM
Kfxguy's Avatar
i have not verified timing. I guess maybe i should, didnt think of that.
You also gave me am idea. It does happen right around the shift recovery. I can add some timing retard on the 1-2 and 2-3 shift. It does jump up in boost right when i shift. Glad you pointed that out. I'm not sure i need to do a compression test yet. I hear no noises and it runs perfect still. I have a very keen ear too. thanks for the suggestions and making me realize that about the shift.
Old Nov 28, 2018 | 03:29 PM
  #32
Kfxguy's Avatar
Plugs just got here (had them delivered to work, I work in parts at a dealership) and man the electrode is inset pretty far!
Old Nov 28, 2018 | 03:31 PM
  #33
3 window's Avatar
Doesn’t seem like much timing (if it’s correct) for 8.5-9 psi to make it rattle. I’ve never messed with pump gas before either, so take that for what it’s worth. I agree though, an easy test would be to knock some timing out of it (like 4 degrees 300 rpms on both sides of the shift recovery rpm) and see what happens. At least that’s what I’d do.
Old Nov 28, 2018 | 03:48 PM
  #34
Kfxguy's Avatar
I am. Its only done this when it was really cold out. It makes 9.8psi on the shift and them settles back down. My logs show 170kpa (10.2psi) on the shift and 160kpa (8.7psi) shortly after
Old Nov 28, 2018 | 07:03 PM
  #35
Kfxguy's Avatar
Just pulled a plug. I have tr5gp in it. Platinum. So that’s even hotter than a tr55?
Old Nov 28, 2018 | 09:58 PM
  #36
Kfxguy's Avatar
Well my dudes, I just want to thank you guys. The plugs appeared to fix it. It idles no different. Drives no different. But when I put the hammer down....she gets it. The detonation was definitely taking big power away because it pulls harder than it ever has. I made a few hits just now and I’m happy. All the plugs that were in it showed no signs of detonation however and looked perfect actually. But I know that’s what I heard for sure. It’s 49 degrees right now so it’s about as cold as it’s been when it was pinging.
Old Nov 28, 2018 | 11:03 PM
  #37
3 window's Avatar
Congrats. Now crank that bitch up!
Old Nov 29, 2018 | 03:04 AM
  #38
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Holy freakin glow plugs, dude. Also, remember to ramp your timing back up after max torque rpm. You will lose a lot of top end power if you don't.
Old Nov 29, 2018 | 03:51 AM
  #39
BCNUL8R's Avatar
Good deal...Were you logging when you heard the knock? I'm curious if it showed KR at the time and how much. Even with the slightest amount of KR less than 1 I found at least one plug with a black spec on the porcelain when I was on pump gas. I'm not sure about the availability of E85 for you, but I think you will love it. When I was at 8 psi on pump I could only run peak timing of 13. After switching to E85 on 11 psi I have peak timing of 17 and never did encounter knock I just stopped there. That was with tr6 plugs in both circumstances. Now I've switched to br7ef plugs and going to 12 psi, but it's winter so the car is put away so I haven't been able to test it out yet.
Old Nov 29, 2018 | 04:32 AM
  #40
Glad to hear!!
