Caprice PPV....new project
I will try to get a comparison pic of the turbos I have together. AGP 5757b, AGP 5757e, on3 7065, garrett gt3071r, vs 6162(gt3582), and a garrett t4 s480.
Decided to go air air intercooler. Ordered this yesterday morning and have it today! https://huronspeed.com/product/huron...es-twin-turbo/ Gonna need a saw...
My friend is doing a zl1 blower on his ppv and will probably use the interchiller I bought.
Also deleted the oil cooler to make room for piping.
Hard to tell from the pic, but the 5757b's obviously provide a bit more ground clearance. The driver side pic has the 90 off the compressor housing super close to the trans but not touching, I dont think. I will clearance the 6l90e in that area when it goes in. Should probably add a section of aluminum to the compressor housing to get the coupler away from the manifold. Going to try to get the intercooler mounted tomorrow.
Worked on the driver side piping today and it is more difficult with the steering shaft and power steering lines. I think I have the hard part done. Got the exa pump today. What size oil return lines are required with a scavenge pump? Going to tee them together before the pump. I am going to mount it on the driver frame rail where the coolant reservoir is on the other side.
Luvin' it, keep it up.
