Mild low 10 sec. setup advice
Old Dec 22, 2018 | 05:53 PM
Kfxguy's Avatar
fuel mileage will largely depend on tuning and driving style.
Smooth idle, there are just so many cams out there that will offer a stock like idle...that isnt a problem at all.
Porting oil pump, and stuff like that is simple and free...so no real reason not to. ARP head studs always good insurance, although for an LS they are pricey. I still couldnt bring myself to buy Chinese though.
LS9 gaskets are cheap too and make sense etc.
A2W is of little real benefit, unless you can use ice. Otherwise keep it simple and A2a, with water/meth if you like.
All the wobbly driveshaft stuff, seems to relate to those who opt for a 1 piece. They all have a very low critical speed due to their length and some questionable build quality. Why the latter seems a mystery.
A good well built 2 piece will be able to run to any speed you'll realistically ever achieve safely and smoothly. A lot of the 1 pieces seem to quote around 150mph limitation ? which is pathetic
And the stock rubbers on most cars dont seem to last very long. For parts supply in the UK, I know some guys were using a BMW rubber donut as they fitted the same and were easier to get hold of, as they are a common wear and tear item.
yea the two piece driveshaft is extremely expensive. I’m trying to avoid that expense for as long as I can. I tried a replacement “heavy duty” bmw guibo one time and shredded it in very short order. I’ll probably buy a couple spare stock ones and just check them from time to time.
I always like to do the free mods. Head porting, oil pump porting. Ronding edges where oil needs to drain back. Just little details. Maybe I will just carry forward with my meth setup. My boost controller has a feature for a flow sensor and it it does not sense water flow it lower the boost to a safe level. So that maybe a really good option
Old Dec 22, 2018 | 06:21 PM
stevieturbo's Avatar
A simple steel shaft wont be expensive.
I had Carolina Driveline make my first 2 piece, and they were very keenly priced. Was actually meant to get one for a friends Monaro a few years back, although only ended up with half as he never followed it up with final measurements.
I bought a GTO shaft and had it sent to them, although the 3 bolt flange made it a little awkward. We bought an adaptor to change it to 4 bolt, but never got around to fitting it or doing anything more.
My current 2 piece steel shaft was from IEDLS, which was just a bearing/centre joint upgrade vs the original Carolina shaft. It was fairly expensive though, probably more than it should have been but they offered what I wanted, when almost nobody else would even make me a 2 piece.
A 2 piece Alloy shaft would be nice though if it could be strong enough.
Old Dec 22, 2018 | 08:40 PM
Tweek's Avatar
I still think your leaving alot on the table by not going E85, it's worth it IMO even if you only use it when going to the track or playing around. My truck made 640 on 11.5lb with low timing on E68 through a 80e. It is a ly6 6.0, but still impressive to me and made me a believer in ethanol.
Old Dec 22, 2018 | 08:53 PM
Kfxguy's Avatar
your probably right. But I plan on running some boostane which from Ive seen in dyno tests the boostane does pretty dang well.
I may go meth. I don’t have any plans for e85. There’s only like one or two pumps in town. I’m not keen on making special trips across town just to get fuel. Then I’ll have to make major fuel system upgrades. Not interested in that right now. If I can get 80% of the gain by using boostane, then it’s a much cheaper route for me. I can order boostane and have it sent to my house. I don’t think I can do that with e85 economically.
Old Dec 22, 2018 | 09:15 PM
BCNUL8R's Avatar
The 2 piece shaft was $9xx alone to my house, but well worth it in my opinion.
Old Dec 22, 2018 | 09:23 PM
Kfxguy's Avatar
that thing does look pretty serious. I’m not spending $900 on a damn driveshaft tho. That’s ridiculous. I have a guy here in town that couple make me a shaft and I can machine my own adapter for the rear. I have a mill and a lathe and a good bit of machining experience. I actually used to work at the place that I speak of. And I worked right around the corner from there at Cam motion lol.
Old Dec 22, 2018 | 11:44 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Kfxguy
good points. However.
1) I plan on upgrading the stubs. I am still running the stock drive shaft with the rubbers. Well I have a more heavy duty 06 model in the car now. I changed the rear end and the driveshaft to match. The shaft and Guibos are a bit bigger.
2) the 4l60, I’m not worried about. I built it and it’s done correctly. I built them to hold up in MUCH harsher applications. Think low 9 sec nitrous car that weighed 4000lbs with driver and put 750 to the wheels. Besides, I have tq management pulling some timing on the shifts.
3) I have a big cooler on it already. I can log my trans temp and it does not increase in temp when I make a pass. It stays 10 degrees below the coolant temp. That tells me it’s not slipping yet. Even with pulling timing on the 2-3 shift it will lightly chirp the tires. Trans is the very least of my worries. It breaks, I build it stronger. No problem.
Also, I was planning on putting a smaller stall in it anyways.
129 on stock heads and cam is impressive.
I do have some nitto nto5r tires I’ll probably run on it my first outing. I have a little voodo controller (I call my cortex ebc that because it’s like magic helping put the power down) that should help me get off the line decently quick but not too harsh. My plan on this setup is to leave about as hard as it did on motor and that netted me 1.7 sixty ft’s. Ramp it in after I’m moving.
The Nitto NT series need a ton of heat to grip properly. I once swapped back to them from my MT DRs on the way home from the 1/4 track. I almost went sideways on the interstate shifting from 3 to 4 because they were cold. They were, however, awesome at Road Atlanta after a couple of warmup laps.
Old Dec 23, 2018 | 12:07 AM
Kfxguy's Avatar
in my never ending quest quest for I can’t decide what the hell I want to do, this definitely is a damn good read. https://www.dragzine.com/tech-storie...inner-crowned/
makes me want to carry forward with meth injection because washer fluid is easier and cheaper to get.
Old Dec 23, 2018 | 03:58 AM
BCNUL8R's Avatar
No excuse not to replace that factory junk driveshaft then. You have a hell of a resume...head porter, trans builder, machinist, welder/fabricator and worked at Cam motion! I have none of those skills, but I can install parts and tune...LOL. Low 10's in a daily is actually not that difficult at all and with that background it should be even more of a walk in the park. I'll probably go with Cam motion to replace my 228r when I build my motor. I'm wanting to get aggressive on the cam, but still work well with the procharger. I'm looking to run mid 9's with no care for gas mileage. I don't like to spend money unnecessarily, but I'm not afraid to spend money on good parts either.
edit to add: I've noticed the mindset on here that all the cool kids build 8 second cars for $2000 with junk yard parts. When I got to the track I find it odd that people pull in with brand new trucks with nice enclosed trailers and roll out a junk yard fox body. This is an extreme case and isn't really directed at you, but a general observation of this site within the last couple years. I don't have a problem driving a beater truck every day while spending money on good parts for the car I'm going to race. I just don't understand the criticism people that put good parts in their car get around here anymore.
Old Dec 23, 2018 | 05:41 AM
Then buy a steel shaft, it will be a lot cheaper than that alu/steel combo.
Old Dec 23, 2018 | 08:47 AM
Gonoma's Avatar
I had Carolina Driveline make my first 2 piece...
Do you live in the Carolinas?
Old Dec 23, 2018 | 08:50 AM
  #32
No...I'm a few thousand miles away in the UK.
But trying to get anything made here sucks.
Old Dec 23, 2018 | 04:49 PM
  #33
Gonoma's Avatar
gotcha, they’re 20min from me is why I ask. They built the one in my truck
Old Dec 23, 2018 | 05:27 PM
  #34
Kfxguy's Avatar
hopefully no one takes what I say about my capabilities as bragging or anything. I only said it to let you guys know me better. Not to brag, I know you didn’t say anything about that but sometimes people will take it as such.
Btw, installing billet turbo today. I’m on my second parts store run as I type this. (Sitting in the parking lot lol).
Old Dec 23, 2018 | 05:56 PM
  #35
They built the first 2 piece shaft I used on my own car, and I would only have great things to say about them.
Then as said, I got half way through getting a custom shaft made for a friends Monaro/GTO....but the front half and rear flange adapter is still sitting on the floor in his house...he just never got around to finishing it.
That must be near 10 years ago lol.
I would definitely give them a call if you need anything.
Old Dec 25, 2018 | 06:40 AM
  #36
BCNUL8R's Avatar
Not at all. It's good to know a persons experience/skill set. I wouldn't recommend fabricating a custom turbo kit for someone that has never welded for example. You've asked a lot of questions over the last several months about things that I would expect someone with your experience, connections, and skill set to already know. Just seemed odd and running low 10's is really pretty easy with a power adder of any type. So basically I'm saying don't stress it so much and go run the car to see what it does then go from there. You have the skills to make it happen just see what it runs and then if it doesn't run as expected trouble shoot it and fix it.
The other part of my rant about the people insisting on using junk yard parts and hating on people that spend money on good new parts wasn't directed at you. I haven't really seen that from you it just fit the topic of the driveshaft debate. You are building a back up motor which is great I'm still trying to decide how much $$$ I want to spend on a motor and what route to take as I want to get a motor ready as well. The issue is you have a good running motor currently so you have time and it may last a long time. My advice from years of being at the track and having a few different low 10 second cars now (I've never gone 9's so that is why I want a solid mid 9 second car this time) is start working on putting better parts in the driveline. That is my only disagreement with what you are doing...just my opinion, but over killing the driveline isn't hurting anything except a couple grand for piece of mind.
Old Dec 25, 2018 | 06:47 AM
  #37
Driveline is important....a broken shaft can cause damage.
And of course breaking something like that at the track, leaves you stranded. Important for someone who actually drives the car.
In all the years I've been driving to/from tracks, and for me it's usually a 400+ mile each way and ferry crossing, only once have I had to be recovered and that was a catastrophic engine failure.
But I've never broken anything in the driveline that has prevented me getting home ( but I have broken various stuff in the driveline ). Securing at least that side of things does make sense. It takes a bit more to do real harm to the engine that would totally prevent you getting home, but takes very little with the driveline to render it undriveable.
Old Dec 25, 2018 | 08:03 AM
  #38
BCNUL8R's Avatar
100% this ^^^
I've always driven my cars to the track because they are street cars. I've had 3 low ten second cars now all driven to and from the track. I believe in building the driveline in any type of car, but over kill on the driveline is essential on a true daily street car. Safety, extra damage caused to other parts when one thing breaks, and getting home are all good reasons to overkill the driveline. If you break something and hurt something else you may have just cost yourself more money long term.
Old Dec 25, 2018 | 08:18 AM
  #39
My closest call, and luckiest was when I had the original IRS in the car.
I brought spare shafts, spare CV's as I knew something was going to break.
But the ******* thing broke an inner CV joint....no problem, easily replaced. After replacing, still no drive, it had also broken the shaft at the outer joint !! ****
Took everything apart,, shaft had sheared at a bit of an angle where the outer splines started. Managed to get it all cleaned up, found a guy at the track with a MIG welder and I welded the shaft back together, then welded the shaft to the inner portion of the CV joint. And that was enough to let me drive home again.
Have broke various gearbox parts too, but I've always had drive to get home ( whether it was silly to drive a few hundred miles or not in that state )
Old Dec 31, 2018 | 10:45 AM
  #40
Kfxguy's Avatar
I just checked the calendar. Track is open sunday the 13th for test and tune. I'm going to try my best to make it there and get some runs in. Found a nice boost leak this weekend too. my damn blowoff valve was leaking pretty badly.
