4th Gen turbo kit that keeps AC
One twin turbo kit I saw completely eliminates getting to the spark plugs from the bottom (which is the only way I know to get the back passenger one) and another completely eliminates getting to them from the top.
Many of us Az guys ditched the AC as I'm not going to drive the car when it's 120* out anyways. That made it a lot easier to control temps and make way more power.
You are gonna have to accept that plug access will be more difficult no matter where you go. Be smart about turbo sizing too. You are building a stock displacement fun daily driver. You do not need a 1200hp turbo......
You could make enough power to make the stock LS1 rods and pistons very unhappy......That is like over 700whp potential. Possibly more....you could search for Billet VSR 7875 results and get an idea.
A 7875 will give more than your ls1 will want to take for any sustained length of time. For reference, I made 900whp with a 76/75 with a 5.3
For what you want, I'd still look into a blower though.Doesn't want a bunch of tubing/pipe cluttering the engine bay- Check
Wants AC without relocating a bunch of crap- Check
No oil lines to tap- Check
Easy on the stock motor with linear power delivery- Check
Stock and/or headers give great plug access- Check
You decide how much power you want based on pulley size and how high you want to rev the motor. And he'd have $5k in the setup at most if he went used with all the head room to grow later on.
Plugs?? shouldn't be a issue with turbos. Some use a oe manifold. Shorty style shouldn't be a issue either.
Tip for left side rear plug, remove the coil packs. Get to it fairly easily then. You can make it even easier by rerouting the heater hoses over the hvac box.
Tubing?? About the only thing you should see is the feed tubing out of the intercooler.
You got me on the oil line tho.
