Piston/rod options
Old Jan 22, 2019 | 09:36 PM
CasperCasper's Avatar
Default Piston/rod options
Well once again I'm torn! I've taken my lq4 apart and have 4th gen pistons and rods for it. Goal is 600whp with a 7875 on pump gas in a second gen camaro 95% street driven. Cars got ls3 heads and a 225 230. Now that I'm pricing out the bit of machine work I need I see that i can upgrade to forged pistons and rods for around $1000. With that being said for 600whp should i :
1. Run the 4th gen pistons and rods (near new, arp bolts)
2. Keep the 4th gen rods and upgrade to forged pistons
3. Sell the 4th gen stuff and go with forged pistons and rods and have something that's probably way over built.
Thanks!
Old Jan 22, 2019 | 09:40 PM
JoeNova's Avatar
Restricted User
Number 1.
I've made 600+ on every single turbo LS setup I've ever built or tuned. All of them on stock pistons and rods.
Upgrading pistons alone is pointless. With proper ring gap and tune, you'll bend the rods before breaking a piston.
The only real reason to do forged pistons on stock rods would be that you had to make a serious change to compression ratio, or had to bore the block.
Old Jan 22, 2019 | 09:49 PM
Originally Posted by JoeNova
Number 1.
thanks! Originally I had the idea that a freshly rebuilt gen 4 with proper ring gap should easily hold 600 but I had some doubts.
Old Jan 23, 2019 | 05:12 AM
yenkomike's Avatar
the gen 3 stuff will live at that level
