Summit ls turbo cams?
correct injector info, idle was bad, but with new info inputted, it really is idling good,
has some lope. With the 6.0 and the 83/75 turbo, seems to light off pretty good. Untill
i get the other trans in, dont want to beat on it to hard, (old switch pitch turbo 400
with a 13" converter) but pretty happy with the cam, prob dyno it in Aug.
Some reason I cant post vids.
Anyway, aside from the theatrics, this cam is way better than the ASA cam. Engine idles down to 750rpm no problem and still has a bit of lope. Nearly no raw fuel smell, ASA cam had 10 degrees of overlap, this cam has -3 degrees of overlap. Idles at 42 kPa, while the ASA cam idled at 58 kPa. After a few days of tuning, at WOT the midrange added 30% more fuel and at 6500 added about 20% fuel. It also pulls much harder in the higher RPMs, while the ASA cam was basically done by 6000rpm, and fuel usage confirms this. So not only is in making more torque, it is making more HP, probably 30HP more. On my drive back, checked fuel consumption and got a boost of 2-3mpg on the highway, logging over 500 miles and two tanks of gas.
So yeah....big improvement.
Andrew
Andrew
