Overspinning alternator, another option.
Old Apr 2, 2019 | 06:30 PM
pdxmotorhead's Avatar
Originally Posted by stilealive
I guess its easy enough to just remove the A/C belt when you get to the track for some runs.
Except that there is only one belt for everything on some cars..
Old Apr 3, 2019 | 03:31 AM
stilealive's Avatar
Well yea....but not our cars and its an LS site.....
Just figuring our cars....
Old Apr 3, 2019 | 11:43 AM
stevieturbo's Avatar
kinda like when my race club ran track days, one of the "prep" items was to un-hook the wire for the AC clutch or pull the AC fuse before going on track, the WOT switch mode would disengage the AC under throttle ,, but re-engaging it when you got on the breaks would get you a LONG squeal until the engine RPM's got down under 4000. the clutches would be red hot after a couple laps.. And because of the fancy electronic temp controls in the cars, you could not totally disable the AC..
AN interesting check,, BMW E46 models, have a nice duct system that looks like it could be repurposed for other applications, it forces air from a CAI through the alternator on the upsized packages for the car.. 2006 3 and I believe 5 series had one..
Some modern Audi's have water cooled alternators. Massive, ******* expensive and utterly stupid lol.
Old Apr 3, 2019 | 02:27 PM
truckdoug's Avatar
90's caddilacs had them too. try explaining to a customer that his alternator is leaking coolant....always a fun conversation
Old Apr 7, 2019 | 05:21 PM
Alt pulley I'm using measures around 70mm wall to wall at the front, and the sidewalls have decent height.
So actual pulley diameter is around 65mm, or 2.5" or so. So not much larger than standard.
Old Apr 7, 2019 | 06:41 PM
rpm-inc's Avatar
Does a belt slipping on the alternator have anything to do with any of this? 04 silverado 6500 rpm. Drive it nice and its fine. Drive it hard a couple times and there is belt dust all over the exit side of the pulley. New Delco tensioner and gatorback belt same thing.
EDIT-AD244 145a
Old Apr 7, 2019 | 07:05 PM
stilealive's Avatar
So if I just order the AD244 170A from those guys and install it....it should live a long time if it sees 3-4 times week hard runs to 6,800rpm.....?
Old Apr 8, 2019 | 11:55 AM
The pulley on mine is larger than standard, so you would need to order whatever you want to order, and pulley sizes etc.
But even an OEM alternator would run quite happily to 6800rpm for quite some time, as the very first unit I ever used did. I seen over 7k quite often with it. Although obviously not very often extended periods at high rpm.
Old Apr 8, 2019 | 03:23 PM
truckdoug's Avatar
EDIT-AD244 145a
yah i prefer a nice iron oxide coating aka patina aka rust to help the belt stick
Old Apr 8, 2019 | 05:31 PM
stilealive's Avatar
Cool I'll order one...thanks.
