LS Swap Supercharger suggestions
Old May 25, 2019 | 10:44 PM
LLLosingit's Avatar
Shorter gearing will absolutely make 1st and 2nd even less use.
And I've a 2.66 first gear and 3.27 rear ( tyre circa 26" ) and it's no issue driving. Certainly never have to excessively slip the clutch unless literally stuck in stop/go traffic. But that's rare for me anyway
If you do encounter that a lot then yes shorter gearing will help, as will a normal organic type clutch if you arent using one already
I drive it 30 miles round trip to work as long as weather permits, Not a lot of stop and go traffic but do encounter it daily, I'd have to say the clutch get released a minimum 30-40 times. It's not really an issue driving but my clutches usually last me 70-80 thousand miles and I doubt this one will make it to 40-50 before it needs replaced. The gear going to be replaced in the near future when I swap to narrowed 9" and run 14" wide tires, At that time I may upgrade the clutch.
