Securing / Sealing T4 Flange
Old Jun 12, 2019 | 10:53 AM
Ericmck2000's Avatar
Default Securing / Sealing T4 Flange
I have had an issue keeping the T4-Divided flange mount secured, and Sealed up.
The first issue I had- a few bolts backed out, and blew out the gasket.
I replaced the bolts with new grade 8 bolts, and lock washers. Did not use a gasket.
So, I recently had an issue where the Holley EFI is oscillating/hunting to get the AFR nailed down. After working with support, they recommended checking the O2 sensor placement (currently around 6in to 1ft post-turbo), and checking for exhaust leaks.
With it running, I did sense a bit of leakage from the T4 Flange.
So, to my question-
I have been reading, a lot of people seal it up with high temp copper: https://www.permatex.com/products/ga...-gasket-maker/ with good results.
Is, that the recommended approach? Also- what method is everybody using to keep the bolts fastened to the flange? While the bolts did appear to be tight still, the lock washers... well. I don't think they work too well after the repeated heat cycles.
Old Jun 12, 2019 | 12:54 PM
truckdoug's Avatar
I usually just used grade 8 bolts and some sort of locking nut. Yeah washers give up the goods after a few heat cycles.
a good hardware store ought to have grade 8 locking nuts. Jet nuts, flex-loc nut or pinch type all work really well.
I try to avoid using gaskets but some stuff you just cant get flat, or sometimes it bows before you get it properly tight. I that case I'll use a stamped steel style gasket.
I've gone as far as using aircraft type safety wire, but that was like last resort fix for some hokey **** done by a previous mechanic
Old Jun 12, 2019 | 02:35 PM
SLOW SEDAN's Avatar
Hate gaskets, love high temp copper, good enough for promods its good enough for me! I've used lock nuts and nordlocks without issue on the turbo flange.
Old Jun 12, 2019 | 03:34 PM
TrendSetter's Avatar
the last few ive done i used whatever cheap stainless gasket came with the turbos, but I put a thin layer of copper rtv on all 4 surfaces then bolt it together. I have never had turbo flange bolts come loose. I like to use whatever 15mm hex head bolts i have in my "ls engine hardware" bucket with lots of anti-sieze.
Old Jun 13, 2019 | 09:10 AM
Black_Sunshine_99's Avatar
Stainless gasket and whatever bolts I had laying around, never had an issue.
Is the hotside or downpipe placing a torsional load on the turbo itself perhaps?
Old Jun 15, 2019 | 02:26 AM
Lsxford's Avatar
I likewise throw the gasket in the trash. If the flange is really flat I just spray them with copper coat, if it's iffy I thin layer copper rtv. Check the flange surface with a straightedge, if it's not flat get it flat. I also tighten the bolts, let the engine run and get hot and tighten them again. Nothing special either just grade 8 flange bolts screwed into a threaded flange.
Old Jun 17, 2019 | 09:53 AM
Is this the stuff?
https://shop.advanceautoparts.com/p/...2160/7160075-P
Old Jun 17, 2019 | 03:02 PM
thats what i always use. great stuff.
Old Jun 18, 2019 | 04:18 PM
imma_stocker's Avatar
Copper liquid gasket works okay on low pressure stuff downstream of turbos. In my experience it blows out too easy under pressure.
These are my go-to guys for gaskets https://www.grimmspeed.com/grimmspee...nifold-gasket/
Been using their MLS gaskets under boost for a long time and was a product tester for a while. You can find these gaskets on amazon too. Extra thick MLS with built in fire ring, not sure what else you could want.
These and STUD the flange for a good seal. Re-torque the studs after a few drive cycles, usually gets another 1/4 to 1/2 turn after fully seated.
Torque spec: TAF
Old Jun 22, 2019 | 04:30 PM
stevieturbo's Avatar
If the flanges are flat, they will not leak.
If they are not flat, make them flat.
Old Jun 23, 2019 | 09:07 PM
sewerpickle's Avatar
Ultra copper, and fine thread bolts with lock nuts, not the nylock nuts either.
Old Jun 24, 2019 | 01:33 PM
I don't believe so, the only thing on top of the flange, is the turbo, and a short section of exhaust pipe.
