Need advice on a good 'fun now boost later' motor build
The 408 will cost twice as much fully configured. I found a rebuilt LS3 for $4k. The 408 will be about $8k
Both will need misc stuff to install in the F-Body as they are both long blocks.
If I kept the LS3 stock and used the stock cam, how would that respond to boost later? Or do you highly recommend upgrading the cam?
Id go LS3 then, $4k goes a long way towards a boosted setup with fueling. As far as cam, it's your call, but while its out of the car its really worth doing some type of cam/spring upgrade. You really should do springs anyways with boost, and any power gain you make NA is going to be amplified under boost. Imagine picking up 40whp from a cam swap, now add 14 psi and that cam swap is worth 80whp and will also lower your boost level which is good because the motor is breathing better.
Also can you recommend me a good thread or something to look at as a good reference as to how to remove my motor? This will be my first time doing it.
LS3 it is, going to be ordering soon, besides the longblock, mods, and all my accessories, and an LS3 intake manifold, is there anything else I need to buy for the conversion?
Nice. I didn't see what this is going in. You'll obviously need things like fuel rails and some type of harness adapter. If it's in a Gen 3 vehicle you'll need a 24x to 58x crank reluctor adapter (LPE sells a plug and play setup). For engine removal, I'm sure someone has a thread on here, but I bought some books off Amazon/book store that show color photos step by step with info that are really useful. Should pick up some of those.
You can reuse most of your gen 3 sensors with a gen 4 motor and reuse the harness. Only difference is installing the knock sensors (most drill/tap the side of the block) and the crank sensor signal. Gen 4 is 58x and Gen 3 is 24x so youll need an adapter that Lingenfelter sells.
Can you link me to what you used on Amazon?
LS3 ordered.
I also ordered the Injector connection conversion terminals, 58x - 24x conversion module, and MAP sensor extension harness.
I noticed the Racetronics LS2 to LS1 knock sensor extension adapter harness on the Lingenfelter store. Is that needed after tapping / drilling the side of the block?
For the Throttle Body, any recommendations?
Can you think of anything else out the ordinary I need?
For fuel, just plain curious how much is the stock fuel pump able to handle? I'm thinking of upgrading that right now as well.
LS3 ordered.
Went with a 92mm Throttle Body.
Ordered Racetronix Fuel Pump and harness kit
Went with Speed Engineering Headers and True Duals
Now I'm onto Cam & Spring selection...
I've been looking around and it seems the general conscience is a properly specced NA Cam Only LS3 is good to 500 RWHP. Only issue is because I am going the boost route in the future (most likely ProCharger but considering a Maggie from Hawks as well), its seeming that I need to get a cam specced for the lower RPM bands as Prochargers powerband in general is gradual through the RPM band.
With a Maggie setup, they are instant torque right at the bottom of the RPM range and I'm guessing a cam would need to be spec'd to help with out in the higher RPM band
This plus valve overlap (decreasing boost pressure) seems to be an issue for either setup.
How much would I 'lose' by going with a NA cam if later I put the procharger (or even maggie) ontop of it?
Its seeming like a Maggie would be more apt for a NA cam given most of them by nature produce their highest yields at the peak of the RPM band where the Maggie begins to lose steam... or do I have it backwards?
If I instead spec a cam for either of those S/C's, how much of a loss will I take over a NA cam? Would 480 RWHP still be obtainable?
#34
So the LS3 is here and I need to pick it up.
What is the best way to lift it to move it onto the truck bed, and again into my garage?
I've been reading some people using the valley cover bolts and others using the bolt holes on the front and back of the heads.
The valley cover bolts are only 10mm, it would scare me to lift from there. The bolt holes on the heads, is it safe to put that much weight on the heads?
#38
#39
On Friday I'm going to be purchasing a new oil pressure sensor, cam sensor, coolant sensor, knock sensors, as well as a cam.
For the cam sensor its sounding like still will use one intended for an LS3 right?
Also anyone happen to know if the Proformer valve covers and ignition coil relocation brackets will fit under the cowl of an F-Body?
#40
Makes sense and thats fine, just out of plain curiosity, when lifting is there any danger of having them too tight?
