Hanging idle and booster vac issue
Old Jul 8, 2019 | 10:19 AM
sti lol's Avatar
Default Hanging idle and booster vac issue
Hey all!
Have a 6L boosted fox and recently became stumped hoping someone has gone through the same issue. After getting on it, the car would hang at the rpm that it was left at. Cruising in the highway was like cruise control. Couldn't get it to idle down. If you start it in P OR N the idle starts off at 18-2000rpm (supposed to be high 800) and if you rev it it will stay at where it went to highest not coming down. Now my IAC is showing good on my Holley digital dash, throttle is DBC and is working properly showing throttle position properly as it should.
The vacuum setup is all new hoses and they are all connected perfectly still. The red flag is my vac hose from the brake booster to the vac block collapses with vacuum. (Can try swap out vac hose for fuel hose but shouldn't need to) The inline valve is the proper way and works when it's out and blow through it. It's the only hose that collapses. Took it off and plugged the vac block where it goes and still nothing changes.... only after a good 18ish pound hit of boost this appeared.
Anyone have ideas. I'm lost as I've basically built this entire deal myself and have run out of ideas. Brake booster faliure with being hit with boost?
Old Jul 8, 2019 | 12:11 PM
stevieturbo's Avatar
It's called tuning. It's clearly tuned/setup badly.
Either throttle open too much, and/or idle valve badly tuned.
If a vac hose is collapsing..clearly that hose is not suitable for vacuum. So use proper hose.
You're going to either need to provide better info on parts or images, as clearly there are multiple issues here.
Old Jul 8, 2019 | 12:16 PM
sti lol's Avatar
Not a bad tune. Ls tuner for 30+ years and a very recognised person in the Canadian car scene. It's ran and been running under boost conditions before.. The vac hose is correct. I will put fuel line instead but still shouldn't be collapsing. There is another issue here. I can give all the info you need. Just need someone to have gone through potentially the similar issue.
Old Jul 8, 2019 | 12:23 PM
if it was built and tuned correctly, there would be no problems.
And it's a little stupid to say a hose is collapsing but is suitable for vacuum....well if it was suitable, it wouldnt be collapsing.
Yes there is another issue....whoever is building and tuning it. What did the tuner say when he was tuning it and these problems were apparent ? Did he not have a look at things ?
And boost is irrelevant...because you arent stating any problems under boost.
Old Jul 8, 2019 | 12:32 PM
sti lol's Avatar
Alright thanks for the help. I'll wait to hear some other ideas.
Old Jul 9, 2019 | 11:57 AM
forcd ind's Avatar
If your booster hose is collapsing, as said, you need a better hose. Are you using a Holley
ECU, what does the IAC position show when high idle. You could have a bad IAC valve, or
a vac leak. Does the CL comp. show a big correction. A large leak will make the computer
add more fuel, thinking you opened the throttle, and if the IAC is out of range, it cant control it.
Old Jul 9, 2019 | 12:03 PM
sti lol's Avatar
I am building a vac leak tester today to check if it's Infact a leak. The booster hose I'll put fuel hose in exchange. Just curious why it has never collapsed and now it does... I was thinking the diaphragm in the brake booster is shot... IAC and TPS show normal.
Old Jul 15, 2019 | 12:09 PM
Project GatTagO's Avatar
What's "normal?"
What is the IAC % when this happens? What is the IAC % at hot idle? What's the IAC hold value? What's the RPM above idle to enable idle control?
Andrew
Old Jul 15, 2019 | 01:23 PM
normal is not having the problems he's having...lol
So what he says is normal...is not normal.
Old Jul 15, 2019 | 04:08 PM
Clearly...
But knowing the things I asked for would certainly give us more clues as to shat is happening.
Andrew
Old Jul 15, 2019 | 04:13 PM
Clearly...
Andrew
I agree...it could be as simple as the throttle blade too far open or an IAC issue, or many other things....but you'd think all of these things would have been covered by his reputable tuner of 30 years, as it would be easy for him when he has the car in front of him.
Sadly trying to diagnose stuff like this remotely, when you cannot get proper answers and the person asking isnt willing to listen etc, is incredibly difficult.
sti lol's Avatar
Clearly...
Andrew
You bet! So whatnot was doing is always dropping to 0. When I'd rev to 2k let's say it would raise to 15.. and hold.. raise rpm to 3k and it would raise to 40 and hold idle. I changed out the IAC and now what's happened is Holley has self learned my incorrect setup and the tune is now off. I am getting my original tune sent to me to load tonight. There was a few issues I dealt with but should be sorted of I can get the tune loaded back to what it was. Self learning is good till there's an issue I guess. Kinda tough when you ask a question and people jump on you though. This is a brand new project. I built it over 3 years and learned as I went. It has been challenging but what I learned most is that the car community has a lot of support and information and there is always the few who belittle you for not knowing what you don't know. Future guys, remember that what you know others don't. I'm proud to say I took a car and swapped an engine and built a turbo kit and fabricated everything myself to what I consider a show car now. Thanks for your help some, to others... Remember you were learning once too.
Old Jul 15, 2019 | 05:04 PM
Everyone is learning...but they need to listen to advice in order to be able to learn, even if it isnt what you want to hear.
That's a huge problem with the internet, people ask questions, but when they dont get the answers they want...they go in a huff. But they will very likely be the answers they need.
Old Jul 15, 2019 | 07:35 PM
forcd ind's Avatar
When you get the tune sent to you, make a copy so you can always have it
to reload. You might turn off the learn while you shoot the trouble. Is it DBW or
cable. Make sure you do a TPS autoset.
Never mind, I forgot it had an IAC.
Guessing it orig ran OK-did you by chance ever weld on it with the ECU in the car?
I did and it hurt the tune, you have to pull all the harness's. What RPM does the
closed loop and learn start at. If you do simple things like even changing vac hoses
around, and its not in CL, it can affect things, engine sees more/less air, idles in
a diff cell.
Old Jul 16, 2019 | 04:02 PM
If it was fine before and now IAC is deteriorating to zero at idle, that indicates a vacuum leak. When you rev it up, the IAC moves to its Hold position, which to me seems like is set to 40 (common setting). but because there is a vacuum leak, when IAC closes, RMP can't drop low enough to enable idle control, blah...blah..blah...
Bottom line, you have a vacuum leak somewhere.
Andrew
Old Jul 16, 2019 | 04:20 PM
sti lol's Avatar
Andrew
Thank you for your input. I built a vacuum leak tester for my turbo inlet to see if it holds vacuum tonight.. Replacing all hoses again with all fuel line hose and see if that helps.
Old Jul 18, 2019 | 11:27 AM
A vacuum leak can also be identified very easily if you know and understand your Holley tune. For instance, I have a Dominator on my 67 Cougar. I know from working with it and tuning it that the normal (everything working properly) it idles at 43-44kPa. If there was a sudden vacuum leak it would immediately start to idle at a higher kPa because the vacuum signal will deteriorate and the MAP sensor will read that as the engine pulling less vacuum.
Andrew
