Let's settle this oil pressure debate.....
Old Jul 12, 2019 | 09:05 AM
  #41
JoeNova's Avatar
Restricted User
Originally Posted by Polyalphaolefin
Most cases would be sufficient with a 30 grade. Even boosted applications (up to a point), I wouldn't advice going up to a 40 or 50 grade. I would advise a superior 30 grade. Oils like Driven LS30 5w-30, Red Line HP 5w-30, HPL Bad *** 5w-30, and LAT Racing 5w-30 put Rotella, Delo, and Delvac 15w-40 to shame in terms of oxidative stability, thermal stability, shear stability, aeration inhibition, and friction reduction.
Diesel oil can certainly still get the job done, but it's leaving a narrower margin for error. A drag racing engine that operates at <200*F with only a short burst at WOT probably won't see much negative effects from diesel oil as the run is over before the effects of aeration start to show. Put that same oil in a NASCAR cup engine, where the oil pump inlet temps are 280*F with bearing temperatures >350*F, and it wouldn't last 2 laps around Daytona. The drag racing engine would still benefit from a superior, lower grade oil as the lower friction, lower pressure-viscosity coefficient, and lower oil pressure all translates into quicker ET through free'd up power, everything else equal.
5w-30 is perfectly fine for a fresh rebuild.
For your average turbocharged 150-200k mile engine, the benefits of 15w-40 or 20w-50 aren't really about lubrication.
The thicker oil won't seep past worn rings or valve stem seals as easily. Any oil that enters the cylinder increases the risk of detonation. Even if the oil itself doesn't cause detonation, the build-up left behind from it will.
Old Jul 12, 2019 | 09:38 AM
  #42
Black_Sunshine_99's Avatar
Excellent post and great info GameOva,
This helps bolster my decision to run a standard volume/pressure pump that will receive internal porting and perhaps a little spring shim.
No one has still been able to confirm whether a HV/HP pump is needed with an oil cooler, I don't think it is since I've been running one with a stock pump for three years now.
Old Jul 12, 2019 | 10:07 AM
  #43
stilealive's Avatar
Seems easy to settle the oil debate........there are many set ups with high flow, low pressure........low flow, high pressure......and every other combo of everything....
They all run and last......
Settled.....
Old Jul 12, 2019 | 10:12 AM
  #44
AndyTA's Avatar
Settled.....
Uhhhh, with all "due" respect:
This right here, is exactly what this thread is trying to do away with. Anyone can come in here with a generalization and seem smart, but that is exactly what prevents proper and detailed information from being shared.
OP Provided a baseline claim, and backed it with pictures.
Will this be true for everyone? Of course not - but at some point as a community, we have to try to reach SOME depth of "absolute" - as best as we can.
Only thing missing from OP is exact bearing clearances.
Old Jul 12, 2019 | 10:16 AM
  #45
Polyalphaolefin's Avatar
Mild to moderate boost doesn't necessitate a change in kinematic viscosity. Neither does wear on an old engine since you'll be long past the top overlay on a bearing before you clearance it enough to warrant a change in viscosity. SAE J300 oil grades tell you little about how an oil performs aside from cold cranking ability (first number) and the kinematic viscosity of the oil @ 212*F (second number). When it comes to determining the load carrying capacity, you need to look at dynamic viscosity which is the viscosity of the oil when a load is applied. The oil's pressure-viscosity coefficient, thermal stability, and shear stability are the biggest determining factors. Just because an oil is viscous in a bottle doesn't mean it stays viscous under load or stays viscous at higher temperature. There's some 30 grade oils out there that beat 50 grades under 15,000 lbs of load at 300*F. A good example of this is with Mobil 1 ESP 0w-40 recommended for the new Corvette. M1 ESP 0w-40 has a higher kinematic viscosity, but M1 ESP 5w-30 and M1 HM 10w-30 both have a higher dynamic viscosity than M1 ESP 0w-40. The SAE J300 oil grading system is far outdated and sometimes misleading.
Oil transport pas the rings can increase with a higher viscosity oil as the thicker oil film means more oil transport past the rings. It also means increased hydrodynamic friction imparted on the rings and pistons. Oils with higher surface affinity will also tend to have higher oil consumption past the rings regardless of viscosity.
Old Jul 12, 2019 | 10:30 AM
  #46
joyridin''s Avatar
I just pulled my engine apart and it had 25 psi of pressure when cold and 25-30 hot. The front main has a groove in it .060" deep and every main is absolutely smoked except for the 4th one back from the front. Had 1 rod bearing that was going bad, but the rest were perfect. There is bearing material all throughout the engine, so everything is getting replaced.
Thar was with 5w-30 oil.
Old Jul 12, 2019 | 10:37 AM
  #47
AndyTA's Avatar
Your oil pressure increased as your temperature increased?
Old Jul 12, 2019 | 10:39 AM
  #48
Game ova's Avatar
I was about to reply to his post, but when I seen yours, I decided that I couldn't have said it better. It's weird how you can have absolute hardcore evidence, backed with pics of your OWN SETUP (no hearsay here), and there will still be those who attempt to refute. This is the very reason I took pics of my bottom end, and even went so far as to provide pics of the mechanical gauge in the car with it running.
Old Jul 12, 2019 | 10:46 AM
  #49
Game ova's Avatar
I look to be on the starter tomorrow, just wanted to leave a couple pics of the setup, as I've gotten many requests for pics in my pm.
Old Jul 12, 2019 | 11:25 AM
  #50
joyridin''s Avatar
Under higher RPM's, yes. Engine had a whopping 6000 miles and was a brand new crate LS3.
Old Jul 12, 2019 | 11:32 AM
  #51
I highly doubt the oil pressure was your issue. You had plenty of oil flow to the bearings. That was assembly or user error. Did the shop warranty it?
Every one of my engines have <20 psi oil pressure at hot idle, and I haven't gotten back a single oil related failure. There was one idiot recently who thought SuperTech was as good as Red Line because he watched a Youtube video, and got mad when I denied the warranty on his wiped cam lobe. That was his error though. A couple of those engines have over 100,000 hard driven miles on them.
Old Jul 12, 2019 | 11:33 AM
  #52
stilealive's Avatar
This oil debate has been going since before the internet and further.....it will be debated in another 20 years too. WHY....because engines live under all scenarios. It just doesn't seem like that big of deal, like every makes it seem.
Now for purpose built, high end, particular types of builds....yes, listen to the builder. But for 99.99% of engines out there......if it has rule-of-thumb pressure just drive it.
Old Jul 12, 2019 | 11:39 AM
  #53
stilealive's Avatar
I'm not refuting anything. Just saying this whole flow vs pressure debate is old as dirt. I have friends that have 10-12 LS builds all basically the same.....383, 416, 427, 402, 390.....some nitrous, some boosted, some N/A. Everyone talks about their different oil pressures and flows and pumps.....yet, after years and years they are all still running and doing fine.
So I'm just saying......its not a bid deal with basic street-strip engines.
Its like oil weights to use.........everyone uses different weights.....everyones engines run forever.....it just doesn't matter for basic street-strip engines.
Old Jul 12, 2019 | 11:48 AM
  #54
There are downsides to having too much oil pressure. The main one being aeration. The higher the oil pressure, the greater the capacity for entrained air, and shorter time to release that air as the oil has less dwell time in the sump. If the oil gets severely aerated and encounters a low pressure area in the system (ie: bearings), the air will release, displacing the oil, and you get cavitation in the bearing. The aeration has to get very bad for this to occur, but I have seen it. Due to this, I always advise a larger oil pan capacity when using a HV or HP pump to increase the oil's dwell time in the pan. If I encounter a situation where higher volume is actually needed, I'm usually ready to go dry sump by that point anyway.
A lesser issue is loss of power trying to pump and maintain the higher volume/pressure.
Old Jul 13, 2019 | 02:12 PM
  #55
RonSSNova's Avatar
My 100k mile LS1 in the vette still has 38psi hot idle. prob 300 passes shifting at 6700.
There is never any sparkle in the oil. I run Mobil 1 extended life 10W30
When I modded it 7 years ago I used the GM performance pump from Tooley.
Nova has been an adventure as I've been stuck in the glitter oil dilemma for the last month.
When the L33 had stock bottom end, I simply disassembled, cleaned, re-gapped rings for boost and reassembled.
After 3 years, max of 19 psi boost, took it apart and all was good. Some shiny spots on mains 2 and 4, typical for boosted deals. Had no clue what the stock bearing clearances were. Should have checked for info. But I didn't.
I decided to amp the thing up and wanted no worries. LJMS rod and piston combo. Had my machinist balance and assemble the short block. Rods were .0025" and the mains were .0019 to .0021". Alum block so the mains will grow. He did align hone it.
Lost the thrust...…...
Clevite 77 and the bearings looked just like GameOva pics. Builder said yuch……...****'s moving around. Max boost was 22.
Shiny spots show metal to metal. Uneven wear shows crank flex.
So fast forward. New forged crank, new high zoot Manley rods. Rods and mains now at .0025". 9 passes, all at 24 psi, metal in the oil. Thrust is still good! King bearings. A little metal in the filter. A lot of piston coating in the filter. Wiseco just missed it on their skirt coating. Half was gone prev assembly.
Sadly, we can't X-ray the engine in the car and see what's wearing. That glitter comes from something. Correct?
BTW, oil pressure still solid.
FWIW I took apart a rat motor recently been abused for a few years and lost a roller lifter. It also had Clevite 77 bearings, but they were coated. Couldn't tell they were even run...…..
I'm going to reassemble the valvetrain and just run mine.
So oil pressure. I used a new cam retainer (easy spot to leak) and went for the fancy Sac City barbell. Even with larger main bearing clearance, oil pressure went up. I run 10W30 Red Line oil. Same GM perf pump I have in the vette.
Point being, there are many "leaks" that can attribute to oil pressure. 20psi hot idle isn't normal, but it works.
Good info man ,appreciate it. As far as settling anything...……..
Ron
Old Jul 13, 2019 | 03:27 PM
  #56
truckdoug's Avatar
another oil thread! classic LS1tech style
in b4 rat540blog
imma start a welding thread just to get the trifecta
oil thread, cocky noob thread, welding argument thread
Old Jul 13, 2019 | 03:51 PM
  #57
in b4 rat540blog
That blog is responsible for at least 5 of my gray hairs. The amount of utter nonsense perpetuated by that blog is mind-blowing.
Old Jul 13, 2019 | 05:16 PM
  #58
truckdoug's Avatar
via Imgflip Meme Generator
Old Jul 13, 2019 | 05:23 PM
  #59
ddnspider's Avatar
in b4 rat540blog
don't forget the NA motor better than boost for anything less than 1000hp
Old Jul 13, 2019 | 07:01 PM
  #60
forcd ind's Avatar
Those old idiot lights took the worry out of driving, lol.
