Matching truck manifolds
if you look in my pictures you can see the right truck manifold hugs the strut tower really nice and perfectly goes around alternator. I’m hoping to find a set that does this on both sides of engine. I’m tight on room as you can see but I’m sure I’m not only one who’s wanted some clean match looks.
What i I have now works, just want it to match each other and meet the requirements of going around top mount accessories. As you can see the pass side manifold just sticks way out past the head.
https://ls1tech.com/forums/conversio...manifolds.html
This thread has pictures of all of them i think.
I was assuming you wanted them symmetrical for a twins setup. No one makes a bolt-on twin setup that ive seen. The Hooker headers manifolds are for a single turbo setup. But they seem to fit nice and snug in every build ive seen them used in. Plus they are priced right. I spent enough on 2" pipe bends, a flex joint, 3" heavy duty bends and v-band flanges to negate any savings over just purchasing the Hooker setup. In fact this winter ill probably ditch my entire hot side for the Hooker log manifold. Get all that hot exhaust pipe out of my engine bay.
if I was going to run the vmount radiator from beginning , I prob would’ve kept the single turbo. I decided twins and then did the vmount. So too late now. Besides twin is pretty bad ***
Hooker header manifolds, are just manifolds, and symmetrical.
