new nova build thread.
Old Sep 11, 2019 | 06:03 AM
  #61
yenkomike's Avatar
fits good. and the only mod to latch is the lower brace is removed. I hope it does good. it is rated just under a treadstone 1245r. for flow. im on e85 so it should be ok . but I will log it.
Old Sep 14, 2019 | 07:23 PM
  #62
yenkomike's Avatar
IT'S ALIVE!!! got it far enuff to start and run for a good while until I realized there was no fan wiring yet. still needs some stuff. but looking better.
Old Sep 15, 2019 | 08:18 AM
  #63
slocaddy's Avatar
Congratulations! Your moving along pretty fast with this build.
To comment on your use of manual boost controller,I have been messing with eletronic greedy boost controller, and while trying figure how to set it, it was spiking to low 20's almost instantly!(learning curve on the duty cycle....)Was really shocked it could build that fast considering how many people complain about slow spool times, it made me think, "compared to what?".......
Old Sep 15, 2019 | 08:31 AM
  #64
3 window's Avatar
IMO the slow spool BS is with people trying to use the compressor housing as the pressure source for the gate and an MBC. Not that it can’t work in some situations, but it’s nothing like having an electronic controller with OBA or CO2.
Old Sep 15, 2019 | 12:33 PM
  #65
yenkomike's Avatar
if you are going to go annual boost control you need to use a spring that gets you a most of the boost itself. and just add a few lbs with the controller . using a 5# spring and shooting for 15# wont work. but a 11# will go mid to upper teens easy. the spring needs to keep control of backpressure while building boost. and most guys have 1.5 times the backpressure as they have boost.
Old Sep 15, 2019 | 12:41 PM
  #66
3 window's Avatar
This ^^^
Old Sep 15, 2019 | 01:15 PM
  #67
47ford's Avatar
The boost control was so easy to hook up in tuner studio when I switched to gold box..... I use the compressor for the source for now and make full boost in under a second on a 1/4 pass
edit: that’s leaving off the two step/foot break at around 8 lb
Old Sep 15, 2019 | 03:04 PM
  #68
truckdoug's Avatar
you guys using the 3 port or 4 port solenoid?
Old Sep 15, 2019 | 04:39 PM
  #69
slocaddy's Avatar
Mine is 3 port,(plummed wrong in the first place, hence the low 20's boo$t spikes...lol)....
Old Sep 20, 2019 | 08:04 AM
  #70
3 window's Avatar
Only running one gate Mike?
Old Sep 20, 2019 | 08:09 AM
  #71
yenkomike's Avatar
no it has 2 44mm gates. will do an update this weekend. with better pics. thanks.
Old Sep 20, 2019 | 11:04 AM
  #72
truckdoug's Avatar
i've been really impressed by the 4 port solenoid. makes 22 + psi on a 7lb spring.
Old Sep 21, 2019 | 11:54 AM
  #73
yenkomike's Avatar
we'll she is out and driving working out a ton of little tweeks but looking better.
Old Sep 21, 2019 | 12:57 PM
  #74
slocaddy's Avatar
Under hood looks nice, whats you driving impression out of boost with this set up compared to old?
Old Sep 21, 2019 | 01:42 PM
  #75
yenkomike's Avatar
engine/trans feels the same but the 400th is a little less load from a stop. the car feels a bit different. it has power steering, power brakes and a locker in the rear. so it street drives better than old blue. we'll see how that locker works at the track.
Old Sep 21, 2019 | 03:18 PM
  #76
slocaddy's Avatar
Was your intake touted as one of the "new thicker" ones?
I think i might be startin to be getting a littte turbo envy.....let me know when your ready to upgrade again lol.
Old Sep 21, 2019 | 04:27 PM
  #77
yenkomike's Avatar
not sure about the intake but they are louder . you can hear the air whistle in them. as far as turbo im really starting to get these 6.0 engine and 80/96 turbo's figured out. they are a very good match if the hotside is right.
Old Sep 21, 2019 | 09:30 PM
  #78
Bad Apache's Avatar
Love to hear feedback on your experience with the locker at the track, running 8's, Which you will!
Old Oct 15, 2019 | 06:37 AM
  #79
yenkomike's Avatar
we'll it looks like im not going to beat the weather this fall and get to the track. think im going to pull the wrap off and start getting it ready for paint. and just get it right for spring.
Old Oct 15, 2019 | 08:07 PM
  #80
Bad Apache's Avatar
Sounds like a good plan!
