9.86 or 10.44 E85 compression ratio..?
Loading dynos use a steady resistance using a strain gauge to measure torque output. This gives you the raw torque output at the rear wheels and then horsepower is calculated from torque (hp = tq x rpm / 5252).
Going from a heavy crank/rod/piston assembly to a much lighter crank/rod/piston assembly will show an increase in power on an inertia dyno, but a decrease in power on a loading dyno due to the changes in rotating mass and how it's measured. Going from heavy wheels and tires to light wheels and tires will show up as a horsepower increase on an inertia dyno.
This is why I advise using the dyno as a tuning tool only, not for real world power numbers. If you want to know how well an engine runs, take it to the track.
This is very true, a dyno is only a tuning tool. I always tell everybody to not get hung up on any dyno number and to take it to the track. The track doesn't lie but dynos do every day.
