Cutting out under WOT in boost areas
9's on any boost is rarely a good idea and could cause issues....especially as some widebands may not be set to actually give values much below a high 9, so it could be significantly richer which WILL cause problems.
Two most important things that I consider when tuning, correct AFR and not too high of timing.
On the other hand, he's stated that he's actually getting 9.5-10.8 in boost, which is probably rich enough to cause significant misfiring (or at least smoking like crazy).
first two files are what I logged with the 11.5 AFR. One is a cruising file and the other is the WOT file. No timing retard really from knock retard that I can see. and my knock sensors do work. Now the funny part is, that I made the changes according to my histograms, but I kept the percentage changed to less than the actual readout to try and keep from over shooting.
SO, I set my Boost Enrichment to 1.0, my PE I set kind of gradual (as gradual as I could). My MAP enable is set to 75 KPA, throttle position is set to 90%. 0-800 RPM EQ is at 1.16 (12.6 AFR) , 1,200-2,000 RPM I set to 1.21 EQ (about 12.0 AFR) (Split the difference between 16 and 26) and 2,400 RPM + is set for 1.26 EQ (11.57 AFR). Does this seem safe? I have noticed going through all kinds of logs from the past that I have never really gone above 100 KPA below 2400 RPM and its generally around 2800 - 3200 RPM that I go above 100 KPA. Only if I brake boost it can I really see above 100KPA before 2400 RPM column.
Lemme know what you guys think!! I am so happy to have this resource available to me, power of teamwork right?? haha
From my understanding reading the descriptions in the tune, is that PE and BE is an either/or function. So whichever one is the richest value, is the one is defaults to. Which would make sense to keep PE safe level that slowly ramps then BE one constant value? Except for higher boost, I guess?
Revert to stock/OL
And dont mess with anything but the BRAF and tune tune tune the VE until I'm comfortable its repeatable until 100 kpa, then start getting into boost.
Thoughts?
i'm sorry i cant look at those tunes & logs, looks like youre on the newest version of HPT doesnt play nice with my v3.36
Only thing that isn't stock on the file so far is:
BRAF
Injector Control
Knock Recovery rate/Burst
Gear ratio final ratio
Limiter
VATS
PRNDL
will update a little later once I set it up for OL, SD, etc.
But the fact you say you're only seeing 110kpa, or 120kpa.....are you sure the map sensor has been calibrated correctly within your ecu ?
