Cutting out under WOT in boost areas
Old Aug 17, 2019 | 03:51 PM
  #41
Soupermn's Avatar
Whilst it is not your problem, that is bullshit. There are plenty of plugs available, colder or hotter.
But the fact you say you're only seeing 110kpa, or 120kpa.....are you sure the map sensor has been calibrated correctly within your ecu ?
Okay, well that's good to know! Thanks for the good news!! I'll have to do some more looking and see what I can find if go crazier later but I've heard that these BR7EF's are good for higher boost.
I was curious about that.. cause in my other test runs today I was seeing "full" boost. But now im wondering about the offset and scalar. But idk. When I was seeing the "full" boost vs this 110 kpa thing the offset and scalar was the same so that's kinda weird. I guess I need to look up my info and make sure its correct. I've never gotten 100kpa on my KOEO though.. should I be concerned about that?
200 and 10.33 is my MAP info
Map is an acdelco from GM 12615136
Old Aug 17, 2019 | 03:55 PM
  #42
Soupermn's Avatar
Originally Posted by 350SS
Is your iat sensor still unplugged?
how does it calc the correct airmass in sd without it?
Yes it is unplugged, it's a apart of the MAF sensor on my truck. So when I got rid of the MAF sensor IAT went with it. Is it needed??? Like plug it in just for the temp reading?
Old Aug 17, 2019 | 04:00 PM
  #43
Soupermn's Avatar
Hang on.....when you're saying 120-140kpa, are you saying that is boost pressure or you're saying it's 20-40kpa above atmosphere (ie NA)??? If you're only making 2 psi of boost no wonder stuffs off. Afr too rich, probably not enough timing and plugs/gap too cold. If 140kpa is boost disregard.
Yes I have been seeing 120-140 on average. Which is why I haven't even considered the map settings, but like I said, even with the same offset and scalar that one run when it didnt cut out I was only seeing 110 kpa... no spring changes or anything funny like that. That's why I equally thought it was weird when I looked at it!!! Could that have possibly been a boost leak?? And that's why I'm not seeing full boost and maybe why it somewhat worked that one time? Idk just spit ballin here. I wish I could post some of the videos I have of it doing it. I can almost guarantee if one of you guys saw what was happening/heard it it would help a bunch.
Old Aug 17, 2019 | 04:27 PM
  #44
stevieturbo's Avatar
100kpa is generally regarded as atmospheric, although some ecu places do seem to deviate from that
Old Aug 17, 2019 | 04:28 PM
  #45
Given you are SD, and MAP sensor is a critical item....of course you should be extremely concerned if it is not at or very close to 100kpa KOEO. Unless you're at some crazy altitude.
Test it, make sure it is right. Otherwise everything is a waste of time
Old Aug 17, 2019 | 04:30 PM
  #46
If it is unplugged and the ecu is expecting it, then it will have defaulted somewhere. Yes that is also a problem. You cant just randomly unplug sensors the ecu expects without consequences.
As to how much it affects tuning...depends on what the person tuning it has told the ecu.
Old Aug 17, 2019 | 04:35 PM
  #47
Soupermn's Avatar
Okay, so the closest I think I ever got to 100KPA was 85 or 88kpa. That was with 200 and 8.0. Now how close should it be? Or what's livable? And what do you consider crazy elevation? I live in Albuquerque, NM where my "base" elevation is around 5500ft, but all around me itll go 2 or 3,000 ft over a few miles.
And by testing.. should I be applying a small amount of pressure or vacuum and reading the voltages to see if its correct?
Thanks for being so patient with me everybody!
Old Aug 17, 2019 | 04:39 PM
  #48
Soupermn's Avatar
That makes sense, when I first unplugged it and thought I was in SD that did give me problems just starting it at first. Took me a little bit of asking around and my own research to figure out which tables I needed to zero out etc, to completely remove the MAF from the situation. But I know with these GM computers that the MAF and SD that they are so intertwined that it can mess things up if not done correctly but I'm fairly certain that the maf has been completely removed.
Old Aug 17, 2019 | 04:41 PM
  #49
Get a mityvac or other device you can apply pressure and vacuum.
Test throughout it's entire operating range that what is displayed on the manual gauge, is what you see on the ecu.
I don't experience altitude changes here....max would be about 1000ft lol.
But around sea level it should be damn close to 100kpa. Maybe a variation of 95-105 at most depending on weather conditions etc.
Old Aug 17, 2019 | 04:57 PM
  #50
Soupermn's Avatar
Alrighty! I do have a mityvac I can use to check the vacuum and make sure its reading what it says it should. I can run a line from my manifold so I can sit the guage near my windshield so I can see what's happening. If I'm not mistaken though my mityvac only does vacuum so I'll have to look at that. If it does read pressure then cool, on with the testing! But if not then I'll have to get a different guage. May have one lying around here at work now that I think about it but first things first make sure the scaling is correct. If it's not correct then would I move the offset until I show what I'm reading on the guage?
Old Aug 17, 2019 | 05:11 PM
  #51
If it's not correct, you need to correct numbers for your ecu. You'd need to speak to HPT, or a tuner or someone who has used your specific sensor or something.
Or you can play with the data and test until it is all correct. I do not use stock ecu's or HPT etc, so cant comment.
Old Aug 17, 2019 | 05:25 PM
  #52
Soupermn's Avatar
Excellent!! Thank you!! I'll do some testing with it in the morning and see what my readings are. Scalar is 200 and I've heard a few different numbers as far as the offset goes anything from 8.0, to 8.33, 10.0, 10.33 etc. I'll just have to play with it I guess and see what's up. Talk to you guys soon!
Old Aug 17, 2019 | 07:00 PM
  #53
JoeNova's Avatar
Restricted User
I finally got around to opening your tune. I haven't read through all of the replies so I'm sure someone has probably mentioned these.
Few red flags.
1. MAP sensor settings aren't correct. You just took the linear and changed it to 200 and left the offset at 10.33. You need to find the correct linear/offset settings for your sensor.
2. You still have a TON of work to do on your DTCs. It doesn't look like you've edited them at all. Some of these have to be changed.
3. You have no hysteresis for your MAP in Power Enrich, its just zero. Your PE settings could use some slight adjusting, but they shouldn't be the cause of your problems.
4. Your IAT sensor is unplugged and is reading below zero temps, causing wide changes to your fueling. This is probably the biggest red flag.
Fix those.
Old Aug 17, 2019 | 07:48 PM
  #54
ddnspider's Avatar
As said no IAT bad, and if you're really only seeing 120kpa that's hardly any boost so check the cold side for leaks.
Old Aug 17, 2019 | 07:50 PM
  #55
Soupermn's Avatar
Few red flags.
Fix those.
Dude!!! You're so awesome!! Thank you so much!! I will address all of those things!!!
As for the map sensor, when I upgraded to the 2bar map os, it had those values in there already so I left them as they were, does this mean changing the min/max map settings too if I do that? Or would I just leave those? But I will look into the proper calibration info.
As for DTC's I thought I had removed what I needed but I will definitely go through those this evening as well to make sure I didnt miss anything. Thank you! Didnt even think about that. I know certain codes can cause a "limp mode" with things or interfere so I need to address those.
I will add the hysteresis back into the file and take a look at my PE values and see if I cant smooth them out a little more.
And as stated I completely removed my MAF sensor from the vehicle, luckily I still have the pigtail wired in, so should I either A. Redhook it back up so i can at least have the temp sensor? Will it still work even with the MAF failed? Or B. Wire in a new temp sensor?
You guys are so awesome thank you all so much for all the help, seems with every post I learn something new. Also, which tune file are you referring to? I've posted a few of them on here, and I'd like to start with the right one.
You guys rock!!
Old Aug 17, 2019 | 08:11 PM
  #56
JoeNova's Avatar
Restricted User
You need to wire in a new temp sensor. You can buy a temp sensor with a pigtail, and you'll just need to splice the 2 wires out of the MAF connector into it.
Also, Innovate widebands are notorious for problems similar to yours. They're basically the Nickleback of widebands
Old Aug 17, 2019 | 08:20 PM
  #57
JoeNova's Avatar
Restricted User
I'll try to make it easy on you. Do them one at a time until it starts getting better.
1. Put a 6 Kpa hysteresis back into the PE.
2. Look up the correct numbers for your MAP sensor and put them into the tune.
3. Buy an IAT sensor with pigtail and mount it either in your intake manifold (plastic GM IAT mounts easily into the EVAP port on a truck manifold with a 1/2" drill bit and a rubber mallet) or in the charge pipe between the intercooler and throttle body (nowhere to mount it on a car intake, so get a weld on bung too). Cut 2 wires out of MAF connector and splice them to new pigtail.
4. Start fixing DTCs for things no longer in use.
5. If it's still not fixed, ditch the Innovate wideband in favor of an AEM, 14point7, etc.
Old Aug 17, 2019 | 10:29 PM
  #58
Soupermn's Avatar
Excellent!!! I love it! I will order a new sensor with pigtail this coming Thursday. Had 30 hours of OT on this check so I should have some "extra" money. (My lady hates when I call it that!) I'm so happy now that I took the time and effort (not to mention money saved) to do my own stock harness modifying. Other wise I'd still be afraid of wiring. So splicing that in will be cake. I will definitely be knocking this stuff out as quickly as possible. But taking care in watching what I'm doing and reporting back what I find as I do! I'll start with the PE and map as stated first. And start looking for an IAT online this evening, plastic case one. I believe my grand prix had an IAT like that, I may even still have it in the intake that I took off that thing... hmmm. I also have my water/meth kit in storage.... once she is fixed!!!
This evening I'll check through my dtcs and see what's up there, get rid of all the stuff I removed from the harness etc. And once all that is complete if it's still acting up I'll definitely look into getting a nicer wideband. I thought mine was a nice one, it got decent reviews at the time and I figured $200 it better be nice Hahaha. Nickelback... love that reference xD. and the tune you were looking at was the first one I posted? Or one further down?
Old Aug 18, 2019 | 05:01 AM
  #59
you cannot just pick any random temperature sensor, they can all use a different resistance curve.
Make sure you pick one that has a correct calibration or is suitable.
Old Aug 18, 2019 | 10:04 AM
  #60
350SS's Avatar
if you want to test out the iat thing, you could always either jumper the two wires from the maf connector to the corresponding pins on the maf (or disconnect the maf wires at the pcm). that way you would be using the stock iat rather than introducing another variable into the equation.
i think this is worth doing and might solve alot of your issues...there are alot of air temp related tables that it would affect having it unplugged...i could be wrong but its easy to test out.
