Maxing our map sensor
Old Aug 21, 2019 | 11:18 AM
BCNUL8R's Avatar
Default Maxing our map sensor
I’m seeing about 14 psi peak and thinking about taking off my air filter at the track. From what I’ve been told this could give me 2 more psi which would max out my 2 bar map.
Will this be similar to timing when it just references the last line? So I can make sure I have accounted for this on the last row of my VE table and should be fine?
Old Aug 21, 2019 | 04:24 PM
stevieturbo's Avatar
If you're happy just tuning the last row, on the understanding if it made more boost than expected at any time....things will go bad, then yes plenty of people have done what you propose.
It may mess up interpolation with rows directly below it...but for a few races not a huge issue.
But why not just do it right with a suitable map sensor that does cover the range you need ?
Old Aug 22, 2019 | 04:01 AM
BCNUL8R's Avatar
It's just a one time thing to see what it gains me at the track.
Old Aug 22, 2019 | 08:08 AM
jordoza's Avatar
All though this is not my personal preference i have done it for a few people and have never had an issue. But it only takes once.
Old Aug 22, 2019 | 08:27 AM
BCNUL8R's Avatar
While I plan to do a forged short block over the winter I prefer to pull out a healthy motor. I don’t drive the car much, but when I do it’s for the purpose of going wide open throttle. The LS1 has held up to 14 psi and 6800 rpm well so far so what’s another 2 psi lol.
Old Aug 22, 2019 | 08:32 AM
jordoza's Avatar
My man. No hero was made acting safe. Lol
Old Aug 22, 2019 | 11:12 AM
wouldnt care at only 2psi. That's such a small difference.
Old Aug 22, 2019 | 12:54 PM
BCNUL8R's Avatar
Sure, but 25 rwhp just from taking off the air filter is worth trying to me.
Old Aug 22, 2019 | 02:18 PM
Kfxguy's Avatar
O ****........maybe i shaould try some 14 psi on my ls1. My tune is always on the safe end. why o why did you have to remind me of this? lol. My trans, rear end, drive shafts, cv shafts.....are all going to really hate me. I think they hate me now as it is.
and yes. The last line is where your fueling will stop. i'd add two or three numbers of fuel to the last line....hell may 4 or 5 to be safe because you dont know what extra boost you are going to make, and then go make a hit.
OR.....
does yours get a little less boost in second gear like mine does? if so, take note of what your boost is in second gear, make a hit with out the filter and see what it goes to. then make an assessment for third gear. I probably would not make a full second gear pull and get some data on my scanner first. then work your way up in the pull and then to third gear. Maybe I'm just scared, but i like to play it safe.
Old Aug 22, 2019 | 02:58 PM
BCNUL8R's Avatar
OR.....
Trans on back is all built pretty well. I'm procharged so boost is consistent in all gears and linear with rpm. I'm at 80% idc at 14 psi at 6800 rpm and high 10's low 11's afr on the gas scale although I'm currently using 70% ethanol so no concerns running out of fuel with 2 more psi. Just wanted to double check that nothing weird was going to happen if I maxed out the map sensor. I have the belief that the procharger is easier on things other than maybe the crank snout, but with the little d1x I don't think even that is an issue.
Old Aug 23, 2019 | 02:42 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you pick up anything that can be noticeable without carefully looking over your datalog, then you have a horrible air filter setup. It is possible you could see 2psi more, but it would be indicative of a more serious system problem.
Old Aug 23, 2019 | 04:45 AM
BCNUL8R's Avatar
The GTO air intake tube does a 180 turn right off the blower then has a small filter to fit behind the head light. It is very restrictive and many people have picked up 2 psi by removing the filter and some even dynoed back to back and gained 25 plus rwhp just by removing the filter.
