Opinions on 418 capability
Old Sep 10, 2019 | 10:36 PM
hillshooter's Avatar
Default Opinions on 418 capability
I know it depends on a lot of variables but I am going to lay out my build I want to know who thinks it can take 30 pounds .
Currently running 23psi with 18 degrees of timing on e85.
ls3 block with a 4.08 wiseco pistons. -15cc dish . 10:1 compression .
callies compstar crank and rods . All ARP hardware . PRC heads .
Cam is a 233/241 .607/.614 117+5
ive been beating on it all season and am running aHolley termi x max through a TH400 .
I see guys running junkyard motors at higher boost levels . Why can’t I? I’d love some opinions , I am going to do it anyway lol
Old Sep 10, 2019 | 10:43 PM
Game ova's Avatar
My opinion is, unless this motor is in a limousine/hellcat, you had better be flirting with 7s with those cubes and that kind of boost. And had better be trapping 175+.
Old Sep 11, 2019 | 12:02 AM
I street race. We don’t have a track here and I live at an average of 7500Da . 23 pounds is a high five in the 1/8th on a dragy . It’s a fifth gen Camaro . 3500 pounds
Old Sep 11, 2019 | 06:09 AM
yenkomike's Avatar
keep an eye on the intake temps if you are going to try that much boost. and back that timing off up there. your getting to the point where 4 bolt heads lift if you do anything wrong at all.
Old Sep 11, 2019 | 08:33 AM
svslow's Avatar
What turbo is it?
Old Sep 11, 2019 | 12:05 PM
good advice. I have the timing coming down as the boost goes up. I lifted some heads last year at around 23 pounds but had a much higher compression ratio.
Originally Posted by svslow
What turbo is it?
Twin 68's from AGP
Old Sep 11, 2019 | 04:48 PM
stevieturbo's Avatar
I know E85 is good...but still sounds like a hell of a lot of boost for that CR.
Old Sep 11, 2019 | 06:19 PM
interesting, so you feel like its more a detonation issue then like a block or head capability?
Old Sep 11, 2019 | 06:35 PM
well detonation and peak cylinder pressures will kill any block/head combo.
Either way, to make best use of the block you have, run at least 625 head studs, or upgrade to 1/2" studs.
And LS9 gaskets are great, but the Athena fire ring gaskets could also be of use too.
I dont think the 4 bolts aspect alone will be a major problem though.
Old Sep 11, 2019 | 08:20 PM
ls3fox's Avatar
7 Second Club
I run a sbe ls3 s480 25psi 16* timing if I were you I would turn the boost up and the timing down
Old Sep 11, 2019 | 08:30 PM
This is what I’m looking for
