Turbo Spool Time Increase
Old Oct 1, 2019 | 10:43 AM
AGM17's Avatar
Default Turbo Spool Time Increase
So I have an F-body with a built LS1, 317 heads, and an On3Performance a/c delete turbo kit. The turbo is a 76mm with a .80 a/r
I have had this for about 2 years and I have decided that I would like to see if I could get a turbo that spools up basically twice as fast, along with some other changes coming down the pipe. Dumb logic says that if I want one that spools twice as fast, then do half the a/r rating and half the size. But I have no clue really. Is there anything I should be looking at when shopping turbos for specific spooling time? Anyone point me in the right direction?
Thanks!
Old Oct 1, 2019 | 10:45 AM
ddnspider's Avatar
What's the turbine wheel size? Auto or manual? How is it tuned?
Old Oct 1, 2019 | 10:46 AM
Mavn's Avatar
"I MAID THEESE"
That thing should spool fast as **** LOL
Old Oct 1, 2019 | 11:03 AM
AGM17's Avatar
Manual, top of my head I don't know the wheel size, and I was not present for the tuning. What tune info are you looking for?
Old Oct 1, 2019 | 11:11 AM
AGM17's Avatar
Here are the 0n3 turbo specs
https://www.on3performance.com/shop/...-turbocharger/
Old Oct 1, 2019 | 11:26 AM
ddnspider's Avatar
Originally Posted by AGM17
A 65mm wheel on a front mount LS should spool nasty quick. Either you have an exhaust leak between the motor and the turbo or your tune needs work. You should be commanding close to NA timing and AFR until you're making a couple PSI, then drop the timing and richen the AFR. What does it spool at now?
Old Oct 1, 2019 | 11:27 AM
JoeNova's Avatar
Restricted User
Those things instaspool on an LS1. Where is it spooling at now?
Old Oct 1, 2019 | 11:31 AM
AGM17's Avatar
Just driving it around I feel full spool around 3800 RPM, maybe a little less, driving hard and watching the dash is tough
Maybe it's being greedy but I don't see why I couldn't feel full boost at 3k rpm or less.
The AFR is 14.7 until i see about 2 psi. Unsure about the timing, I could ask about that
Old Oct 1, 2019 | 11:36 AM
ddnspider's Avatar
I would shoot for NA WOT AFR (like mid 12's) and see what it does. And timing matters, especially on a stick car.
Old Oct 1, 2019 | 11:38 AM
AGM17's Avatar
At WOT and full boost it's about 11.5 AFR
Old Oct 1, 2019 | 12:09 PM
JoeNova's Avatar
Restricted User
You're going to need a way to datalog to get the exact RPM numbers.
3800 is extremely late for a single 7665 on an LS1. That's where my 4.8 spools my quads.
Old Oct 1, 2019 | 12:28 PM
ddnspider's Avatar
Try setting it to 12.5 until you have a few psi, then drop to 11.5. And check on timing.
Old Oct 1, 2019 | 01:08 PM
SLOW SEDAN's Avatar
14.7, who tuned this thing? Poor thing needs fuel to make power to get going! Should be 12.8 or so tipping in to WOT NA (95-100kpa), hold 12.5 or so for a few psi, then taper down to your desired max boost at 11.5 (which it seems that part is there, sounds like you just need to work on the middle).
Like others said, your 7665 should spool pretty damn fast. Are you using a boost controller? What boost?
Old Oct 1, 2019 | 01:58 PM
gsteele's Avatar
If you are not data logging and are just "feeling", how do you know that you are not at full boost? Depending on what "full boost" means, you also will not achieve it in whatever gears you are traction limited.
Old Oct 2, 2019 | 10:20 AM
AGM17's Avatar
The car is mainly a street car, which gets driven daily. The desire for a 14.7 ratio was to keep the mpg in check so that trips to the station didn't happen daily. I will put 300 miles on this car in one day, just high way driving if i have things to do that day.
Manual boost controller, currently it pushes 13psi at WOT
Old Oct 2, 2019 | 10:25 AM
ddnspider's Avatar
Your idle and cruise AFR should NOT be your WOT AFR.
Old Oct 2, 2019 | 10:42 AM
LSX Power Tuning's Avatar
Timing and fueling have a HUGE effect on spooling.
Old Oct 2, 2019 | 11:19 AM
SLOW SEDAN's Avatar
Almost all the cars here are street cars, doesn't mean they cant be tuned to run optimally. Stoich cruise, throttle tip in and WOT A/F are completely different things.
Usually an electronic controller will get things spooled quicker then a manual one. But I would fix the fueling before you go throwing more boost at it faster.
Right! LOL Although in the LSA world I've seen some tuners not have them far off.
Old Oct 2, 2019 | 11:45 AM
AGM17's Avatar
WOT = 11.5-12
Idle = 14.7
Old Oct 2, 2019 | 11:47 AM
SLOW SEDAN's Avatar
WOT = 11.5-12
Idle = 14.7
You said your setup was lean until 2PSI and want faster spool, the ramp between 14.7 and 11.5 greatly impacts that!
