Torqamp Electric Supercharger
Old 10-05-2019, 12:49 AM
SHARKBITEATTACK's Avatar
Default Torqamp Electric Supercharger
Anyone think this could achieve decent results on an LS?
Old 10-05-2019, 06:28 AM
forcd ind's Avatar
LS1Tech 10 Year
48 volts, need some serious batteries, and alt.
Old 10-05-2019, 07:25 AM
ddnspider's Avatar
Received 1,751 Likes on 1,307 Posts
LS1Tech 20 Year Member
It comes with a lithium polymer battery that is boosted to 48V from the stock charging system......I was more concerned around the SIX lb/min of airflow lol
Old 10-05-2019, 10:45 AM
AnotherWs6's Avatar
20 percent more power on a NA 2.0 motor. Wow.
Old 10-05-2019, 11:50 AM
Jimbo1367's Avatar
LS1Tech 10 Year
WOW. I’m sure you’re really impressed. LOL 😆
Old 10-05-2019, 07:00 PM
jimmyg's Avatar
Cletus bought a $400 electric turbo and put it on a 97 mustang gt . Car lost 39rwhp
Old 10-05-2019, 07:17 PM
ddnspider's Avatar
It doesn't exist yet. It's a Kickstarter.
Old 10-05-2019, 09:32 PM
JosephIV's Avatar
How the hell would you control boost? Have some kind of variable resistor that increases current based off of Throttle Position?
Old 10-05-2019, 11:06 PM
Restricted User
JoeNova's Avatar
It's an electric motor. Boost control would be far easier than current methods since you can directly and precisely control the RPM of the compressor.
These wont be offered for an LS anytime soon, they just aren't big enough and the motors to move that much air would have to be much much bigger.
Old 11-17-2019, 02:53 PM
Dragframe's Avatar
They sent one of these to Cleetus and he did a video on it. Put it on a cobalt and made like 40more horse or something. Really works lol
Old 11-17-2019, 04:47 PM
jayyyw's Avatar
peaked at 5psi and tapered off to around 3.
Old 11-17-2019, 06:06 PM
Krom's Avatar
Wonder how long until an F1 MGUH style turbo starts seeing mass production??
For those who don't know its more or less a turbo with electric motor hooked to the shaft. You can send electricity to it to build boost instantly when you want it, and use it as an alternator to charge its battery when there is enough exhaust flow, or on decell
Old 11-18-2019, 12:38 PM
FourG63 97GST's Avatar
Old 11-18-2019, 12:42 PM
Kfxguy's Avatar
I'm pretty sure it made 20hp from the NA baseline. It lost 20hp when they put the thing on and didnt turn it on....then picked up 40hp from that by turning it on....which isnt truly adding 20hp to the baseline of what the engine was without it.
Old 11-18-2019, 12:44 PM
Kfxguy's Avatar
and for the record, that "turbo" is way too small to feed a v8.....its needs to be quite a bit bigger and turn more rpms. This will become a reality once all of that is figured out.
Old 11-20-2019, 09:32 PM
rpturbo's Avatar
LS1Tech 10 Year
I don't see this being cost effective and that's just the basic problem. It would only support a 2.0 LTR @3 psi, so just get a junkyard turbo for $50 off any import. Cletus still did a tune for it, so there's that.
Old 11-20-2019, 10:28 PM
Dragframe's Avatar
Very well could but here is the issue... a turbo is nearly free power generates from the waste of the engine anyways. Only benefit of running a turbine with a electric motor is bringing in the turbo whenever needed rather than working around the exhaust, housing and turbine, cubes, cam.... you just turn it on and it goes all the rpms.
but in a drag racing application, we have other more cost efficient ways to get around the turbo power curve.
idk I’m just thinking out loud but I can’t see it really being a sensible alternative to exhaust driven turbos.
Old 02-15-2020, 07:54 AM
Mike Milner's Avatar
This isn’t quite true ... it ran 123hp baseline, then dropped 13hp to 110hp with torqamp connected but off. Then rose to 146hp with torqamp on and then 157hp with torqamp on and better fuel.
That is definitely a positive result.
Quick Reply: Torqamp Electric Supercharger
