What heads?
Old Oct 14, 2019 | 01:16 PM
stangeater01's Avatar
Default What heads?
Building a sbe 5.3 has 862 heads doing a twin turbo build gt35s should I keep the heads or put the stock ls1 heads
Old Oct 18, 2019 | 08:50 PM
tblentrprz's Avatar
Not much difference in 862/706 vs 241. 241 CC chamber is larger so will drop compression. Doesn't sound like you have a hp goal requiring a better head.
Old Oct 18, 2019 | 10:33 PM
01CamaroSSTx's Avatar
There's people throwing 18-19 lbs to a set of ported 317's and don't see why 241's wouldn't work better than the 862's as they have larger intake valves and combustion chambers.
Old Oct 19, 2019 | 08:03 PM
JoeNova's Avatar
Restricted User
Flow on a turbo 5.3 is almost irrelevant between the stock castings, and lowering compression will only reduce power and torque without much benefit to knock supression.
Old Oct 19, 2019 | 10:49 PM
krazy4's Avatar
Just run the 862's.
Old Oct 20, 2019 | 06:51 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Boosted cars don't need to change parts until they blow off. All of the stuff that matters on an NA build matter just as much when boosted, but the difference is an NA build has no choice, where a boosted build can just add a little more boost.
Old Oct 21, 2019 | 12:53 PM
bluestreak98's Avatar
Ive pushed my gen 3 5.3 SBE with 241 heads to 24-26lbs. Its just what I had when putting everything together so I ran them.
Old Oct 21, 2019 | 03:13 PM
Originally Posted by bluestreak98
ive pushed my gen 3 5.3 sbe with 241 heads to 24-26lbs. Its just what i had when putting everything together so i ran them.
thats promising what year did your 5.3 come out of?
Old Oct 21, 2019 | 03:24 PM
1999 silverado
