.96AR ve 1.25AR?
well I have the duty cycle at 100% so I don’t think it can compensate at that point. I made my gate manually adjustable long ago so I can dial it in or add a little bit more spring pressure if I ever need more power. I turned the dome screw in some last night and tightened up all my clamps to make sure it’s all sealed good. I’ll take it for a spin in a little while and see if it added some boost.
i get what you are saying. And that’s what I was thinking last night, but….say I’m making 20psi and I’ve got 30psi (I’m just throwing a number out there because I never checked it) of backpressure. Then say I lower that backpressure to 15-20psi, so now the motor is flowing more air through it. The boost should be lower because it can get in and out easier. I dunno, maybe I’m wrong. But I have no exhaust leaks I can find, so I have no other explanation.
so I think we might both be wrong. The cutout frees up a restriction after the turbine, and the bigger housing frees up a restriction IN the housing….which will slow the gasses speed down and the flow won’t be as concentrated and pushing on the wheel as hard.
https://www.garrettmotion.com/news/n...-turbo-system/
“The turbine housing is nothing more than a nozzle, designed to speed up the exhaust flow. The speed determines the angle the exhaust hits the turbine wheel. By going to a bigger nozzle (bigger a/r), the gas isn't being sped up as much as with the .96 housing, this means it's slower and therefore doesn't "drive" the turbine as hard. Which means less shaft speed, less compressor rpms. Less rpms means the compressors exducer isn't going as fast so it can't produce the same boost level as before.
The reason you gain boost with a cut out is because you are decreasing backpressure behind the turbo, allowing the turbine to get a higher expansion ratio.”
the garret link really just shows bigger ar = more top end power at the expense of spool rate , which is what everyone would expect . They don't mention whether boost went up or down from just the swap and I'm guessing they did what they had to get it the same.
I'll try to make this short , about 40 years ago in trade school the subject was Detroit diesel tune up procedure with a drawing of a 2 cycle dd with turbo and blower (think 6-71) so I ask the instructor -do they use a different camshaft in the turbo engines to close the exhaust valves earlier to stop the boost from going straight out the exhaust. He said - don't know and nobody ever asked that before LOL. He checked with some people and no ,Same cam. So I figured it out , the only reason those engines can build boost is by having exhaust back pressure. Anyways how does this apply to our stuff ? Lower back pressure means less exhaust left in the CC and more room for charge air which means less restriction to flow on the intake which would lower boost pressure ( not power or flow ) mostly trying to explain how kfx got lower boost after the swap . Like I said earlier, there's a lot a variables at work here , from valve events to intake / intercooler restrictions and where on the compressor map you end up when you increase flow , how much power/torque/rpm the turbine is able to produce with a different housing. Most of this over my head for sure , that's why I just try to use what others have had good results with lol and this housing swap is something I'm considering but someone has else to prove it's worth while LOL. This is my understanding of the whole thing, keep the great info coming !!
