.96AR ve 1.25AR?
Old Dec 13, 2021 | 09:22 PM
  #61
Kfxguy's Avatar
I guess I'm struggling to see how a DECREASE in pre turbine back pressure would result in less boost, especially with a controller that targets a set boost as a closed loop system. I can appreciate that you're blowing through a larger straw but it's into the same size wheel. If we're talking fractions of a psi then sure but multiple PSI just doesn't seem right.
well firstly we may have our lines crossed a bit. The boost controller isn’t targeting a set boost. I’m not using it like that. Im using it in the duty cycle mode. I don’t set a target boost. Doing it that way is way more involved and I just never felt like messing with it in that way because this was quicker and easier.
I screwed the screw in all the way just for kicks. In second gear it got 20.2psi with the controller set to off and it on gate only. My guess is either now I have too much spring or the screw is keeping that gate closed. That’s a good sign tho, I’ve never had 20psi in second. Usually a max of 17-18, maybe 19 on a cold night and a passenger with me. So at least I know once I set the spring pressure it will make the boost I want.
Old Dec 13, 2021 | 09:25 PM
  #62
Kfxguy's Avatar
Originally Posted by GMCGreg
Which boost controller targets a specific boost ? Everything I've seen and used just goes by duty cycle with some overboost protection. I'd be very interested in something that actually targets a specific psi . As long as it's affordable
look up cortex boost controller. That’s what I have and it WILL target a particular boost pressure if you set it up that way. I was lazy and did it the beginner route and it worked good enough I never felt the need to mess with it.
Old Dec 13, 2021 | 09:48 PM
  #63
Kfxguy's Avatar
Jesus. What a shitshow I have going on right now lol. So turn boost controller off. Make a rip. Cutout closed. 5psi of boost. Open cutout, make another rip. 13-15psi. The problem with that is when I have the controller set to off, my second fuel pump doesn’t get kicked on and it leans out. Jesus.
I guess I’m gonna have to set one setting to no duty cycle.
Old Dec 14, 2021 | 07:21 AM
  #64
ddnspider's Avatar
I missed this. I thought the controller was targeting a set PSI! That certainly changes things.
Old Dec 15, 2021 | 10:35 PM
  #65
Kfxguy's Avatar
I got things better with it. Fixed the over boost with the controller off. Now I’m back at 5.5psi with it off and the cutout open. 4.5psi with cutout closed.
I logged 17.1psi in second gear turned up with cutout open. I added some timing in and out of boost. I think adding some timing right before (basically when I hit it) it goes into boost and it has hardly any lag now. I’m getting it more where I want it to be. At first I was doubting my change with the housing in some ways. The extra lag I didn’t like, but it was liveable. The extra top end power on the same and little less boost was definitely welcome and so is the added response out of boost. I guess I was thinking it was gonna be a straight swap and not have to mess with anything else. I should have known better. The added timing that it’ll tolerate definitely helped. I’m waiting on my tires to come in so I can plan on a drag strip trip.
