Sizing Log Style Header
Old Oct 22, 2019 | 04:11 PM
Shownomercy's Avatar
Man-Crush Warning
Default Sizing Log Style Header
Redoing my hotside this winter and want to simplify it to gain ground clearance.
383ci SBC, T4 76mm PTE, etc. Not a LSX.
Current plan is to have a 2in log on driver side that feeds into pax 2.5in log and then maintains 2.5in into turbo.
Are those diameters sufficient?
Old Oct 22, 2019 | 05:07 PM
stevieturbo's Avatar
https://ls1tech.com/forums/forced-in...over-pipe.html
Old Oct 22, 2019 | 05:24 PM
Man-Crush Warning
Yea I am an idiot for missing that gem.
I will stick with my plan then.
Old Oct 22, 2019 | 05:36 PM
When I measured the OEM truck type manifolds, They only ended up around 2" inside or thereabouts. For my twins mounted almost direct onto the truck manifolds ( with some modding and re-welding of course ) I opted for 2" ID Sch10 type pipe. Just didnt seem any sense going bigger, especially when the hole inside the scroll of the turbo was only around 1.5" anyway.
Old Oct 22, 2019 | 06:23 PM
forcd ind's Avatar
I have a log manifold on the PS, I think its 2.5" or 3", uses a 2.5 cross over to the DS-I used that because
thats what the V band was on the log. I had planned on a truck manifold on the DS, but had a tight
fit Pat. Perf. header laying around, so i used that. Not sure how the 4 ind. pipes into a 2.5 affects
the velocity, as opposed to a truck manifold. But I was thinking of switching to the truck manifold to gain
better plug access. I have a short piece of the orig exhaust pipe so i was going to use that as opposed
to a V clamp. The pipe actually is around 2.5", but as said the manifold is 2" at the flange. Prob.
blowing thru a 2" into a 2.5" doesn't do wonders for velocity. GM designed the firing order for what
they built it to do, always wondered if it could be altered to comp. a turbo, if there was some advantage.
Old Oct 22, 2019 | 06:29 PM
Man-Crush Warning
Was doing some more head scratching and I think I am just going to to 2in log that each feed into the merge at T4 flange. If I can make that work, that would be optimal.
Old Oct 23, 2019 | 11:44 AM
Man-Crush Warning
So as I am stuck with crappy D port heads, and I want to minimize the amount of fab work required. Thinking of laser cutting a flange that has circle ports for SCH10 1.25 OD stuff. Square dotted is head port, circle is the elbow diameter.
Should I be concerned with the overlap?
Most of me is thinking is a 383ci motor pushing a T4 76mm and its overkill to begin with so the overlap won't hurt.
