Quick turbo 5.3 sbe question
Old Oct 22, 2019 | 09:22 PM
stangeater01's Avatar
Default Quick turbo 5.3 sbe question
Used the search and haven't found anything but doing a sbe 5.3 turbo build and have option to get a lower mile 2008 5.3 will this engine be ok looking for 700 or so hp.
Thanks in advance
Old Oct 23, 2019 | 01:26 AM
80/TA/LT1's Avatar
YUP
Old Oct 23, 2019 | 02:00 AM
Dragframe's Avatar
It’ll be perfect! 4th gen rods and ls6 heads. Just remember the 07+ has a 58x reluctor wheel one the crank rather then a 24x
Old Oct 23, 2019 | 07:53 AM
Originally Posted by dragframe
it’ll be perfect! 4th gen rods and ls6 heads. Just remember the 07+ has a 58x reluctor wheel one the crank rather then a 24x
i have a harness and computer off a 2001 1500 silverado will this work?
Old Oct 23, 2019 | 08:30 AM
JoeNova's Avatar
Restricted User
No, that won't work with an 08.
Old Oct 23, 2019 | 08:40 AM
ddnspider's Avatar
LPE makes a 58x to 24x converter box to run a GEN 3 PCM with a GEN 4 motor.
Old Oct 23, 2019 | 09:57 AM
SLOW SEDAN's Avatar
By the time you buy that, a wideband and a boost controller, may as well go Holley!
Old Oct 23, 2019 | 10:04 AM
ddnspider's Avatar
depends on what you spend for a boost controller. The 58x to 24x works well if you just want to drop a GEN 4 motor in an Fbody with a stock PCM and everything like gauges function.
Old Oct 23, 2019 | 10:51 AM
SLOW SEDAN's Avatar
Well you can get Holley for about $800 now, so minus the $275 conversion box, $150 wideband, $150 boost controller, and then factor in HPtuners costs of $100-$500.
Old Oct 23, 2019 | 10:59 AM
ddnspider's Avatar
Sure, there are instances when the Holly makes sense. But not always. Plenty of people already have EFI Live/HPT so no cost there. They want factory gauges and are good with a $10 manual boost controller. Just different strokes.
Old Oct 23, 2019 | 11:22 AM
SLOW SEDAN's Avatar
Lots of instances it makes sense! Especially when shops are knocking people over the head for $600-1000 tunes and the engine didn't even cost that much. You can make factory gauges work if you take the time to do it. Jesus I pity the fool using a $10 controller lol
Old Oct 23, 2019 | 11:39 AM
ddnspider's Avatar
Now I have to factor in a shop doing the tuning instead of me?! Come on man!!
Old Oct 23, 2019 | 12:09 PM
SLOW SEDAN's Avatar
Not saying you in particular, rather the other 95.68% that don't do it themselves.
Old Oct 23, 2019 | 12:21 PM
ddnspider's Avatar
I think it's actually 95.69%. just saying
tell m about the holley I am doing a budget build right not to make some noise since my kid is interested but plan on doing a true/ not budget build in the future and could use the holley
Old Oct 23, 2019 | 01:02 PM
SLOW SEDAN's Avatar
You can get a plug and play harness and ECM now from Holley, solid start to getting your stuff up and running as fast as possible without any converter boxes or doodads.
You can get this from Summit or Jegs when they have the sales ($100 off), or Holley's black Friday sale wont be too far away: https://www.holley.com/products/fuel...parts/550-905T
Old Oct 23, 2019 | 02:32 PM
JoeNova's Avatar
Restricted User
Hey now, the $10 manual boost controllers definitely come in handy lol.
You should see the torque we picked up using one to eliminate crack pressure from a wastegate with an 11 PSI spring in it lol.
Old Oct 23, 2019 | 02:53 PM
SLOW SEDAN's Avatar
Honda guys use a 50 cent vacuum tee to do the same thing lol
