air flow sensor distance
Old Nov 4, 2019 | 12:09 AM
hotrodtrimmer's Avatar
Default air flow sensor distance
someone pointed out today that my air flow sensor was too close to the intake butterfly on my twin turbo ls1 (4"away) !!!!!!!!!! was told it will not give a true reading so what do you guys think ??
was also advised as it will be difficult to mount elsewhere and to go maffless instead so again any input will be much appreciated
Old Nov 4, 2019 | 12:12 AM
[img][/img]
4" away
Old Nov 4, 2019 | 12:13 AM
Old Nov 4, 2019 | 09:03 AM
truckdoug's Avatar
oooh subbed for answers. thats a neat set up
Old Nov 4, 2019 | 10:45 AM
JoeNova's Avatar
Restricted User
I like the fab work, but all I can do is wish you the best of luck.
Blow-through MAF (in a tapered housing) with that intake/TB combo?
Hopefully your tuner is good.
Old Nov 4, 2019 | 12:01 PM
im not responsible for the build as ive bought it like this and to be very truthful im an old skool hot rodder so this is all new to me so I am all ears to take any advice as this is like going back to school .
so what are your suggestion's guys n gals
Old Nov 4, 2019 | 12:21 PM
jayyyw's Avatar
Are you having issues with it? I've always read 4-6" from the TB. If you're not having issues, then I wouldn't worry about it. If you are, go maf-less (SD).
Old Nov 4, 2019 | 01:10 PM
RonSSNova's Avatar
That’s an odd looking MAF sensor. Never seen one like that
Old Nov 4, 2019 | 02:00 PM
truckdoug's Avatar
killer lookin truck!
Old Nov 4, 2019 | 02:52 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Yeah, that truck is awesome.
That said, as others have suggested, if its a problem, ditch it and go SD. If its working, then its only a problem in someones mind
Old Nov 7, 2019 | 03:21 PM
stevieturbo's Avatar
Dump the MAF.
But if you must use a MAF....they must be placed in smooth airflow, ideally in a straight line of a few inches either side.
Which totally rules out the possibility on your setup,
Old Nov 8, 2019 | 12:23 AM
Dump the MAF.
thank you ...........................looks like that's the way to go then
Old Nov 8, 2019 | 09:49 AM
randeez's Avatar
as said, the maf is just correlating air flow to fueling. it does like smooth transfer of air across it but if tuner can use it then it works, you dont have any other placement with those charge pipes, the only improvement that could be done would be to join the 2 charge pipes a few inches lower and run a larger 4" single up to the throttle body. the larger charge pipe would allow the maf to sample a greater area.
also killer truck man, love the set up
