Throttle body options?
Old Dec 5, 2019 | 08:55 PM
ls1bumblebee's Avatar
Default Throttle body options?
When i bought my motor, the throttle body did not come with it. I do have the truck manifold but no TB. So what are good options for a turbo 5.3. I am not a fan of the DBW and i have a gen 4. It is a 4 bolt and i know most will say run a stocker, in that case do i get a gen 3 and an adapter plate or? Any one have luck with the WARR TBS? Any other suggestions or comments would help! Thanks!
Old Dec 5, 2019 | 08:57 PM
Dragframe's Avatar
There is lot of pretty cheap cable 4 bolt throttle bodies available on the market.
some companies want a rediculous amount of money for their throttle bodies. I don’t get it because there is a whole lot less going on in a efi tb than day in a carburetor.
Old Dec 5, 2019 | 09:08 PM
truckdoug's Avatar
get a truck 3 bolt dbc and the adapter. good to 1000 hp and no weird bullshit like i have seen with aftermarket TB's
Old Dec 5, 2019 | 09:17 PM
ive seen some decent looking TBS for good pricing but im reading more and more into it and see issues occurring with the cheapers. My build is budget minded and theres no way im putting a $400 TB on my stock intake lol
I know they get the job done for sure. Thats kind of the route im thinking about after reading more and more horror stories on cheaper TB's. Thanks for your input guys.
Old Dec 5, 2019 | 10:05 PM
Kfxguy's Avatar
this.
Old Dec 6, 2019 | 06:40 AM
forcd ind's Avatar
As said, get the truck TB and adapter. Better than any cheap TB.
Old Dec 6, 2019 | 02:23 PM
truckdoug's Avatar
in the past year i've tuned so many cars with terrible chinese TB's
that is like #1 on my "sorry i cant help you" list
Old Dec 6, 2019 | 03:14 PM
huggerls1's Avatar
Ive seen good results with the WARR. There is actually one for sale right now on here. I plan on using one for my 5.3 with TBSS intake el camino i am building.
Old Dec 6, 2019 | 06:14 PM
Dragframe's Avatar
Yup I kinda gotta disagree with every one on here. Although Im currently using stock tb’s on all my junk.... My friends have never had a problem with cheap throttle bodies besides maybe having to open up the iac hole (no tuning complaints like you hear so much).
Though I would look for a “decent“ cheap tb like WARR (they have a solid track record).
They work good, and look so much better on your $6000 turbo setup than a ugly 3 bolt truck TB.
Old Dec 6, 2019 | 07:31 PM
ls3fox's Avatar
7 Second Club
I have used both a cheap china t.b. And a Warr t.b. The Warr is better but the cheap one wasn’t bad either
Old Dec 6, 2019 | 10:36 PM
truckdoug's Avatar
imo if you just have to have the aesthetic use the holley or edelbrock 90mm.
the bullshit ive seen on the lower end ones is incredible. massively undersized IAC passages, blades that dont align correctly, undersize shaft so the TPS reads 0%, then 2% then 0% then 4% all of which make tuning a cammed turbo car a big stupid hassle for very little return.
you saved $200 on your TB, rad. But then you paid me $500 to make it not run like steamy dog ****.
damn i guess I have a little salt on this subject haha
actually, nevermind I said anything please continue to buy those things lol I got a mortgage to pay
Old Dec 7, 2019 | 06:26 AM
forcd ind's Avatar
Last 2 projects I used the Edelbrock 90, quality piece, plus I had a 4 bolt intake.
I had a name brand higher dollar TB for one project, the V that the cable rides in was wider
than others, so the barrel on the end of the cable couldnt stay in place bet. the guides.
I even called the man. about it, they didnt have much of a solution. So I guess that was
one case where money didint make a diff. I forget the brand name.
Old Dec 7, 2019 | 06:39 AM
stevieturbo's Avatar
Or just use stock gold blade DBW
Old Dec 7, 2019 | 09:53 AM
truckdoug's Avatar
nick williams ring a bell? yeah i've seen issues with those too.
Old Dec 7, 2019 | 01:37 PM
Dragframe's Avatar
Pretty sad to hear that because like I said earlier, it’s not a overly complicated part and much more simple than a carb. They should be $2-400 and dead reliable
Old Dec 7, 2019 | 03:05 PM
truckdoug's Avatar
people get hung up on the bigger is better. ditching a 78mm truck TB for a holley or edelbrock for aesthetics sure I get that.
but going to a 102 on a drive by cable FI car all you are doing is making your life harder and losing throttle resolution.
here's an ugly truck 78mm making 1000 wheel, locked
and another making ~600 unlocked
Old Dec 7, 2019 | 09:43 PM
Dragframe's Avatar
https://youtu.be/IotsTFy8bgk
https://youtu.be/XtEY_bauyQc?t=595
has nothing to do with it not working. It’s all I’ve ever used on my junk. But They are ugly lol. Not everyone wants to be Matt Happel. Kinda wanna have something that looks as good as it runs
Old Dec 8, 2019 | 06:04 AM
forcd ind's Avatar
I tried to remember who's it was, but dont want to post the wrong name-just made no sense to
build it that way-as I remember it was the steel linkage, not the alumn. style used on a lot of
them. I have seen massive power out of a GM DBW, hard to believe.
Old Dec 12, 2019 | 09:52 AM
If i went cheap it would definitely be a WARR tb. Ive heard good things about them and denmah trusts em so that says alot to me. I also think that the stockers are a great quality piece. I wouldnt buy a quality piece to put on the junk yard build. I know the stock is good for 1000ish hp and i cant imagine making more than that. Anyone run the WARR with boost and good results?
Old Dec 12, 2019 | 12:34 PM
ls3fox's Avatar
7 Second Club
I run a Warr 102 I haven’t any issues with it and I got the one without the breather tube
