Relocation mount for mini alternator
Old Dec 12, 2019 | 06:56 PM
rick539's Avatar
Default Relocation mount for mini alternator
Recommendations of a relocation mount that a mini alternator will fit on. Will drive directly from balancer (10% under drive). Forward facing, down turned headers, Moroso elect water pump. Thanks
Old Dec 12, 2019 | 07:12 PM
Dragframe's Avatar
No idea what mini alternator you have. Hell
i don’t even know what alternator I have 😂.
This is just a low mount I think I bought off eBay. But I’m driving the water pump and using a katech manual tensioner
if your gunna drive directly off the crank with nothing else... the alternator mount is gunna have to be adjustable like they were on old school stuff
Old Dec 15, 2019 | 02:05 PM
rick539's Avatar
you can see the room availability. Passenger low gives me a little more separation from the headers. Have a denso mini lesson like to fit in somewhere.
Old Dec 15, 2019 | 05:36 PM
Dragframe's Avatar
Yeah From the looks of it... the combination of those headers and a electric water pump doesn’t leave you with much of any options.
Old Dec 25, 2019 | 01:17 PM
gjohnsonws6's Avatar
Bob at AEI makes a passenger low mount mini bracket.
Old Dec 25, 2019 | 04:54 PM
ddnspider's Avatar
Seems like a bracket bolted to the pass side head would be easiest. Run a low mount tensioner/idler setup and it should work.
Old Dec 25, 2019 | 05:58 PM
Dragframe's Avatar
Electric water pump kinda makes that spot hard.
he is almost going to need a low mount that is adjustable. Kinda like the old v belt setups were on a SBC. Loosen a bolt and use a pry bar to pull the belt tight and tighten the bolt on the alternator
Old Dec 25, 2019 | 06:00 PM
Dragframe's Avatar
http://www.aeicnc.com/lsx-super-mini...or-kit-rh.html
Old Dec 25, 2019 | 07:01 PM
rpturbo's Avatar
What is this setup in? I was thinking you had a dime, but that's clearly not a dime.
Old Dec 25, 2019 | 07:07 PM
ddnspider's Avatar
I still think it'll fit depending on water line routing.
