Knock sensors on dominator?
I dont run the holley system and my ecu wont pull timing if a problem rears its ugly head, so I set up a J&S safegaurd Interceptor system on my turbo , pumpgas LS3. I think it's the best 500 bucks I spent on the entire car ! Its wired into each of my coils and if I get any knock, it pulls 10* of timing in the cylinder that showed it was starting to knock . I'm pretty sure the holley dominator has provisions to read the knock sensors on your 5.3. It would be foolish to not take advantage of that engine safety system.
Merry Christmas to you as well, my friend.
I'm watching your build. I'm interested to see what that little 5.3 can do with a borg 88, turned up on kill ! What kind of rpms are you expecting to turn ? That borg is gonna want to move some air .
https://forums.holley.com/showthread...ors-Holley-EFI
They're not something you just plug in and toss in the formula and are good to go. Good fuel and conservative timing is a more practical, safe plan for engine longevity than relying on knock sensors.
Recently rode with my buddy while he had Los Vasquez remote tune the procharged 6.0 in his 454ss. First thing he did was turn it completely off.
Well of course his engine builder was pissed and we thought that seemed off. I talked to a couple people and both had lots of issues with them (on the Holley system) pulling timing regardless of the timing, or knock settings. So they ended up shutting them off as well. Could not tune out the “noise”
my opinion... if you can use them.. leave them in play to be a last ditch effort to save your engine in worst case situations... something more important in a street car situation. A purpose built drag car being tuned for every ounce of power is going to have plugs pulled and checked every round. And if your doing this.. knock sensors feedback is irrelevant. Reading plugs is king (nitrous guys know all about that.. and watching Pan Vac...plugs and pan vac will tell everything)
if the holley system has problems with their knock detector system , I would recommend the setup I use. It really allows you to dial it in for your noise and even gives you the opportunity to use it for timing control in boost . It also has a headphone Jack so you or your tuner has a way to listen to the engine knock sensors and help dial the tune right to the ragged edge of that's your goal .and most importantly to me, it pulls a bunch of timing if it hears knock , so the piston that's in trouble can cool back down quicker. I read somewhere that the gm ecu only pulls 2 to 4 degrees at the sound of knock. The system I use pulls either 10 degrees or 20 degrees, depending on whether the user is confident of their tune or not. It also allows for gang retard or individual retard if knock is heard . While your tuning you can use the gang retard and the 10 or 20 degree drop in timing will let you know your pushing things because the engine will fall on its face . Once your happy with your tune, set it for individual cylinder knock retard so in cases of a freak incident of knock, it only retards that cylinder . That avoids the massive power drop and somewhat saves your run. For less than 600 bucks, it might be the best bargain out there for someone with big money invested in a turbo ,
thank you
Not sure, I think im gonna talk with the tuner and ask him what he thinks about it. Yes pretty big turbo for a 5.3
