Recommended 408ci compression
Old Feb 21, 2020 | 03:47 PM
HioSSilver's Avatar
Srk gets owned by me. You get owned by me. You block my comments because you have no answers for your junks abysmal performance. I show no respect to those idiots because they don't deserve it....just like you don't. You're to big of a ***** to even read someone's comments but yet will make comments on them......nuff said
I don't want to build a turbo motor. But if i were i wouldn't lower the cylinder pressure just to raise it again. I mean i guess you think guys boosting gen3 coyotes are complete idiots with them having 12.2:1 compression.
Of course he won't see this because he's to weak minded unless someone quotes it.
Old Feb 21, 2020 | 04:57 PM
HioSSilver's Avatar
Sorry op for the derailment. For any question of where it started refer to post 14.
Old Feb 22, 2020 | 08:40 AM
islander033's Avatar
7 Second Club
Why is Hiollary in the FI section? She blows **** up NA at vacuum...lol
Old Feb 22, 2020 | 10:04 AM
HioSSilver's Avatar
More proof of you following me around and lying like a love sick school girl.
Old Feb 22, 2020 | 10:08 AM
SLOW SEDAN's Avatar
What turbo are you using on the 408? Aiming for a smaller or larger cam?
Keep backpressure in mind, generally with higher backpressure you get away with lower timing. Run too high of compression and won’t be able to run much timing at all on pump fuel. Combine those and you run into limitations on power before reaching your hp goal. I’ve run 20psi on an 11:1 engine on pump but timing was in the dirt and it also wasnt 1200hp. Engines in the 9.5-10.5 range seem to do very well in street cars with higher boost goals.
If goal is truly 1200hp I would look into at least a meth kit or a way to get e85. You can certainly get away with higher compression on E85 as well.
Old Feb 22, 2020 | 10:21 AM
7 Second Club
I'm a fan of 10.5, I run e85 on my slow car and race gas on my quicker car.
Old Feb 23, 2020 | 12:39 PM
po feng's Avatar
[QUOTE = islander033; 20213422]我是10.5的粉絲,我在慢速賽車上運行e85,在更快的賽車上運行競賽汽油。[/ QUOTE]
Hello sir.
you engine is 408ci?
10.5 compression ,Is the computer easy to adjust?
Because I use 98 fuel, I am afraid that it is not easy to adjust.
so 10:1 compression ok?
Thank you.
Old Feb 23, 2020 | 12:44 PM
po feng's Avatar
Thumbs up
There's no reason you can't if you spec the combo right. Let the boost do the work instead of the compression ratio. If you're able to, add a methanol injection kit for some margin. Hio just wants to matter so badly on here he comments on stuff he has no clue about. Ask if he's built a 12:1 turbocharged motor on pump gas. I block his comments and only see when someone quotes him because he's literally been laughed out of this section for spewing garbage. Even the SRK section is fed up with him. He shows no respect, so he gets none.
ok.This way I understand.
Old Feb 23, 2020 | 12:45 PM
po feng's Avatar
What head do you use?
Combustion chamber cc?
Old Feb 23, 2020 | 07:44 PM
7 Second Club
It's 4v mod motor crap....
Old Feb 24, 2020 | 07:40 AM
HioSSilver's Avatar
To drive my point home on what a pos he is.....he's in here yappin with a 4v.
Thanks ddbuttsniper, slow duffis. You made my point for me.
Old Feb 25, 2020 | 04:39 PM
  #32
7 Second Club
But it’s turbo (forced induction section) and leaves you 1320ft behind with your LS that makes milk shakes under vac! Lol
Old Feb 26, 2020 | 02:46 PM
  #33
HioSSilver's Avatar
And you just made my point even more so.....thanks.
Old Feb 26, 2020 | 02:50 PM
  #34
7 Second Club
I’m happy we all agree that Hiollary has no business in the FI section.
Old Feb 26, 2020 | 02:55 PM
  #35
HioSSilver's Avatar
I can be in any section. But why would a furd bitch boi be in this section??? No reason unless he's in here harassing someone. It's not like you could answer op question....or any questions about ls stuff for that matter. Now run along chump.
Old Feb 26, 2020 | 03:25 PM
  #36
7 Second Club
Ya, why would a guy that can’t keep motors alive NA and make milk shakes under vac be in the FI section?
Tell the class about your 4 NA motors you’ve wrecked running low 11s and your blower fox that can’t touch a 10. Lol
Old Feb 26, 2020 | 03:50 PM
  #37
HioSSilver's Avatar
I can tell them about your lies if you like.
Old Feb 26, 2020 | 04:08 PM
  #38
7 Second Club
put a turbo on your LS....show us how fast you can be with FI and 12:1 compression on pump gas. Lolol
Old Feb 26, 2020 | 04:15 PM
  #39
HioSSilver's Avatar
I don't want a turbo on it. We know you can't get past the 12s w/o boost.....I'm not that guy.
Old Feb 26, 2020 | 08:43 PM
  #40
SLOW SEDAN's Avatar
Nobody cares how fast anyone is NA, thats just an excuse for why you lost and couldn't build a faster car. From a quick glance it looks like islander is 4 seconds faster then you’ve ever been and that’s all this forum cares about.
