Lm7 turbo daily driver
Gap rings for boost
PAC 1218
Trunnion valve upgrade
Cam .585 lift .050 228/230 lope 112
Cast 7875
44mm wg
50mm bov
Deka 80
ARP head studs, main studs
Stronger rods
Lq9 head gasket
(Have to get stronger fuel pump, Tranny, and good tune)
Thanks
Trunion upgrade is a good idea but not mandatory.
600 hp on a Gen IV 5.3 is a breeze on pump gas only and will live forever with a good tune.
I'm making 700whp with the same turbo on a SBE LS1 with the smaller Gen III rods for going on five years now pump gas only, a good tune is key, look up Pat G.
You should use a stock bottom end including ring gaps. You put forged stuff in there and then its all on the machinist to make sure its matched better than the stock stuff was. There just is no practical reason to change anything in the bottom end for anything 600-700hp. A factory lm7 from a junk yard will make 600hp with a turbo on all stock internals with the exception of maybe changing the valve springs. I ran mine totally stock at 10psi on 91 octane with no ping.
If your choice of cam is driven mainly by price rather than getting a dedicated turbo cam, you'd be better off with the SummitRacing SUM-8715 Ghost Cam.
600whp daily.
I dont think its worth the trouble opening up the engine just for 600. Unless you want to for fun
I'd splurge on a good turbo cam and springs though, it'll make the number easier with less boost required.
for a daily driver my preference would be a smaller cam ( something in the 21x dur) allowing a lower stall or stock converter and better fuel economy. Depending on vehicle weight and gearing of course.
have you considered using decapped injectors ? Eric Derr the guy to talk with. Save some money for other stuff
I think you asked about water/meth injection - I'm a big fan for both short term benefits
- charge cooling , maybe don't need the best intercooler
- increased octane from the meth
- anti detonation properties of the water
and the long term benefits
- steam cleaning of the combustion chambers , no carbon to create hot spots and pre-ignition
if nothing else it's good insurance and could save you the trouble of swapping in another engine
Do spray water only or meth only because I didn't think you could do both?
I know very little about eithe rbut have been considering it for my boosted car lately.
Thanks.
I would say the best way of running 50/50 is finding a local race gas shop in your area that sells straight methanol in barrels. Then mix desired ratio %.
The way I decided on 50/50 is I Data log my IAT to see how much it climb at boost. I wanted to drop it since temp was high so I run 50/50.
Keep in mind you need to calculate your nozzle size, decide if you want to run pre-turbo or post only.
Buy a new stock pump, shim the spring with a washer or two to boost pressure and port the passage ways inside.
Plenty of guys going crazy fast on big power doing just that, plus its cheap insurance.
