How good are the ebay 78/75 Turbos?
Old May 22, 2020 | 05:49 AM
Stampede4ever's Avatar
Default How good are the ebay 78/75 Turbos?
Looking at the cheaper ebay 78/75, "Universal T4 A/R .81 hot .75 A/R cold T78 78/75 billet Racing Turbo charger". If it can make 600-750 hp and live without issues, I'm good with that. I have an older GT45 turbo, and man that thing is heavy!!
Let me know your thoughts.
Thanks.
Old May 22, 2020 | 09:05 AM
ddnspider's Avatar
I love mine. Was $260 shipped. Spools quick on my manual rear mount turbo and hits 15 psi no problem. Major upgrade over a GT45.
Old May 22, 2020 | 11:43 AM
Wow, a manual and with remount. Then I should be good to go!!!
Thanks.
Old May 22, 2020 | 01:09 PM
truckdoug's Avatar
i should know later this weekend! fingers crossed
Old May 22, 2020 | 02:50 PM
I was hoping you would reply, I didn't know if you had a VS or ebay 78/75.
Old May 22, 2020 | 03:31 PM
truckdoug's Avatar
yeah i rolled the dice and got the super cheapie this time. i figure its been on the market long enough they probably have it dialed in mfg wise. just started the truck for the first time...yep the spiny boi spins
Old May 28, 2020 | 08:45 AM
rel3rd's Avatar
Just curious if you've tried, or thought about, pushing it a bit higher than 15psi?
Or is it pretty much topped out at that point?
For $260, I might grab one just to compare against the (probably made in the same building) cast VS Racing 78/75 cast one I have,
Old May 28, 2020 | 09:28 AM
ddnspider's Avatar
I am a high compression cast rotating 5.7 though on pump+ windshield washer fluid so I am trying to be reasonable with the boost. I haven't gotten the impression that the turbo is maxxed though. It doesn't have a problem revving to 7k and seems like there's more in it.
Old May 28, 2020 | 11:26 AM
Forcefed86's Avatar
Local just made 1200whp with a cast set of 78/75 ebay cheapies on a mild 370" LS. 28lbs.
Old May 28, 2020 | 11:40 AM
rel3rd's Avatar
Thumbs up
That's crazy. For the cost, especially.
That's even more crazy, lol.
Old May 28, 2020 | 11:51 AM
DETHS5THGEN's Avatar
Wow! That's cool!
