ATI crank pin kit
Old Jun 28, 2020 | 08:57 AM
62vette's Avatar
Default ATI crank pin kit
ok guys where have i gone wrong gen 3 5.3 block with gen4 5.3 crank ATI pin kit 918993 gonig to fit damper ATI 917345 crank snout is about 5/16 out
Old Jun 28, 2020 | 11:52 AM
RonSSNova's Avatar
I have that pin kit and used it many times.
Is that a stock cover?
If you remove the cover does the tool butt up against the oil pump drive?
Ron
Old Jun 28, 2020 | 11:54 AM
forcd ind's Avatar
I'll have to ck, I think there is 2 diff kits, or 2 diff instructions-I have one in the garage that worked, let me look at it.
Old Jun 28, 2020 | 01:20 PM
62vette's Avatar
Ron
the 1st photo is with the cover off and against the crank sprocket
Old Jun 28, 2020 | 02:23 PM
forcd ind's Avatar
I took some meas., from the end of my crank to the crank gear, where it jams, is aprx. 1.290, or just under 1 5/16".
If you meas. the tool, the smaller dia length is .830, meas. from where the end where it hits the crank gear to where it steps up.
Old Jun 28, 2020 | 02:40 PM
62vette's Avatar
end of my crank to crank gear is 1 1/8 toying with putting the tool on back to front it might work
Old Jun 28, 2020 | 02:58 PM
forcd ind's Avatar
Either the crank gear isnt on all the way, or someone may have cut some of the crank snout off for some reason. If you rev. it, it will put the drilled end further away from the end of the crank. You could pull the cover, and crank gear, maybe make a spacer to hold the tool out some, and drill it-one caution, when you get to the honing part, be careful, dont make the hole to big. Only other solution would be to use the Procharger style, where you drill thru the front, splits the hole bet the balancer and crank.
Old Jun 28, 2020 | 03:52 PM
RonSSNova's Avatar
I have a crank and gear sitting here.
The length of the crank snout is 3.00"
The length of the stock crank gear/pump drive is 1.725"
Which leaves 1.275" of crank past the gear.
These dimensions are the same gen 3 to gen 4
You might have to pull the pump and measure. Can't imagine the crank snout is too short.
Old Jun 28, 2020 | 04:26 PM
Twin_Turbo's Avatar
Do you by any chance have an ls7 front cover there? Doesnt look like it. Looks normal depth. Still the crank looks short... but hard to judge from the pics
Old Jun 28, 2020 | 08:54 PM
RonSSNova's Avatar
I photo'd mine when I did it on my LS1
Your crank looks correct.
Wondering, do you have a double roller chain? With the separate oil pump drive?
Might have the wrong drive. They are shorter.
Ron
Old Jun 29, 2020 | 02:38 AM
62vette's Avatar
the engine is a bit of a bitsa gen 3 block gen 4 internals it came with an LS4 front cover so now wondering if the crank is an ls4 (13mm shorter)will drop pan and check will also try the tool on reversed with the cover off may work
Old Jun 29, 2020 | 08:40 AM
forcd ind's Avatar
My friend owns ATI, so i sent him an email, I remember a while back I ran into something diff on these things. There is a 918993-1 that is for the front dist. drive setups, verify you dont have the dash 1 tool, although it seems you dont.
Old Jun 29, 2020 | 11:21 AM
RonSSNova's Avatar
Ah. Learn something new every day!
The LS4 isn’t mentioned here hardly at all.
Old Jun 29, 2020 | 11:57 AM
forcd ind's Avatar
I had forgotten all about the LS4, isnt that the sideways mounted engine? If I remember right, the crank is diff in the rear also, takes a smaller FW or something, so I guess they had the shorter snout also.
Old Jun 29, 2020 | 11:59 AM
62vette's Avatar
i believe i have the right kit just a short crank. i removed the oil pump cover and can now fit the tool on backwards which should work just need to make sure its in line with the timing gear sprocket/oil pumpdrive cut out or i will have trouble getting them of. will drop sump+confirm crank no to see if it is an LS4
Old Jun 29, 2020 | 03:25 PM
RonSSNova's Avatar
I didn’t line up my first one with the crank key. After that I did. Sure simplifies things at disassembly down the road.
Old Jun 29, 2020 | 06:29 PM
stevieturbo's Avatar
use a kit that does an axial pin, like a round keyway.
Those radial pins give such low surface area....certainly not the strongest solution.
Old Jul 13, 2020 | 01:50 PM
62vette's Avatar
checked my crank and it is a 5.3/5.7/6.0 not LS4 just short so mocked up my procharger and alignment seems fine so will pin it and carry on
Old Jul 13, 2020 | 05:07 PM
RonSSNova's Avatar
Cool. That's just how I do it. A little hard to see the lines through the drill fixture, but works great.
Old Jul 13, 2020 | 05:58 PM
1FastBrick's Avatar
That is an LS4 Crank. The LS4 crank uses the same casting but the snout is machined shorter. Same with the rear flange.
I bought an LS4 for parts and wanted to see what was different on the crank. That's when I noticed the casting number was the same on the crank. I Measured the snout just to be sure.
