ATI crank pin kit
Old Jul 14, 2020 | 01:00 AM
62vette's Avatar
Originally Posted by 1FastBrick
That is an LS4 Crank. The LS4 crank uses the same casting but the snout is machined shorter. Same with the rear flange.
I bought an LS4 for parts and wanted to see what was different on the crank. That's when I noticed the casting number was the same on the crank. I Measured the snout just to be sure.
thats good to know everywhere i looked gave a different part no for LS4 crank 12568920 which threw me off
Old Jul 14, 2020 | 10:56 AM
RonSSNova's Avatar
Interesting. Hopefully the rear flange being different isn’t an issue for you.
Old Jul 14, 2020 | 11:10 AM
stevieturbo's Avatar
If it's on a stand now....might make sure the crank is what you need, while it's relatively easy to change.
Old Jul 14, 2020 | 11:11 AM
1FastBrick's Avatar
Unfortunately, the Part Number does not always reflect the Casting Number.
I didn't take any pictures of the crank side of the LS4 but I Think it's still sitting in the Scrap Pile. If I can remember, I will get some photos the next time I am there.
It's cheaper to buy the long block rather than just the individual parts I needed from it.
Old Jul 16, 2020 | 09:01 PM
1FastBrick's Avatar
So here is the LS4 with crank still installed with a truck crank from a 5.3 next to it with the same casting number.
tried to also get you guys measurement best I could.
Look closely at the rear snout. It's not machined the same for a standard RWD torque converter. It does also have a thinner rear flange. I locked the calipers at the truck crank thickness for comparison. Anything else before it disappears?
LS4 crank snout numbers
Old Jul 17, 2020 | 04:41 AM
62vette's Avatar
thank you foy your help again MrBrick as Ron stated i will mock up my convertor and check clearances i have a ptc with extended snout so hopefully it will be ok the engine is allready built/balanced
Old Jul 17, 2020 | 06:36 AM
forcd ind's Avatar
They say the rear flange is 3 MM shorter, so a reg starter prob wont engage properly, and you may have to much converter pull out. You will need a spacer, maybe use the .450 80E spacer and machine it down, or have one made. Prob the converter snout would be made longer to still reg into the crank. Not to ad confusion, just something to think about.
Old Jul 17, 2020 | 10:02 AM
62vette's Avatar
spacer sounds good i will know what i am working with after after measuring unfortunatly i have put my back out so maybe a week before i get back on it
Old Jul 17, 2020 | 07:21 PM
62vette's Avatar
Looks like comp engineering flexplate shims will work
Old Jul 17, 2020 | 07:36 PM
1FastBrick's Avatar
No problem. With your back out in the other post, What about the center portion of the crank where the convertor pilot rides? I didn't take a measurement but you can physically see its smaller.
Old Jul 18, 2020 | 04:58 AM
62vette's Avatar
Yeah looks like the next issue to overcome diameter is the same but it sure is lacking depth once i have measured up i will know what i am dealing with at the minute thinking a modified snout extender and
possibly some off the convertor snout if i need it
