Twin 67/66 Lazy...Help
It is open at idle which I have not seen before on a BOV...Is that ok?
Any ideas on how to seal it? It is a V band style connection.
You could setup your phone to take a video of it during a quick pull? Should be pretty easy to see?
But certainly a proper ball bearing turbo should spin very freely, and on shutdown they tend to keep spinning for some time.
On a previous Camaro i installed the AGP twin kit which used T3 57/57 on a bone stock LS3, never had an issue the turbos came on strong and fast.
I'm really at a lose on this one...
But check or get rid of that BOV to try. ( and plug the hole if you do of course )
But surely it cant be that difficult ?
or at least take it apart to inspect if it is even capable of sealing. If it can physically close on its own and there is some spring pressure on it, just apply a boost line to the top, no vac and see if that makes a difference
Id look into that.
Id look into that.
I dont plan on changing springs anytime soon, my car is just a street/daily/full interior/AC car.
